What did you do to or buy for your XJ-S/XJS today?
Old 09-30-2017, 06:38 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Originally Posted by warrjon
Looks a million $ Daim. I bet you can't wait to get it up and running.
You bet Warren! I think the zinc plating is a nice 'gold' look and gives it a little 'bling'. I already have an expectation for when the TÜV inspector does his import check over... Oh, now zis is not very Yaguar. Vhere is ze oil!? Zis does not leak!
This will purr like a kitty and should give me a nice long ownership with very little issues when running again. A lot more to do yet though! My plan is to have the engine running by mid 2018. Then the rear axle is due. Hopefully to be finished by the 22nd of September 2019, as that would be the 30th birthday *
  #842
Old 10-03-2017, 07:41 AM
Daim's Avatar
My A6 compressor i now in bits...
More here: https://www.jaguarforums.com/forum/x...3/#post1769764
Jonathan-W (10-06-2017)
  #843
Old 10-05-2017, 11:44 PM
TTG*'s Avatar
New Headliner is in right before winter storage.
  #844
Old 10-08-2017, 06:04 AM
Asdrewq's Avatar
Had my replacement front subframe returned from the shotblasters. Mmmm clean:
It's nice actually being able to handle a part of my XJS without needing gloves!
I've just covered it in a nice layer of Epoxy Mastic 121.
Greg in France (10-08-2017)
  #845
Old 10-08-2017, 06:34 AM
Greg in France's Avatar
Received 9,342 Likes on 5,478 Posts
Andrew
What does it cost to have it blasted, roughly?
Greg
  #846
Old 10-08-2017, 09:19 AM
Asdrewq's Avatar
Quoted £40 for just the subframe. I had the suspension arms, spring pans & engine mount brackets done too for £80 all in. Worth mentioning this was proper sand blasting, leaving the rough sand blast finish on all parts, even those without rust, so probably not suited to machined surfaces.
I had it done at A & C shotblasting, Newbury.
  #847
Old 10-08-2017, 09:20 AM
Daim's Avatar
Andrew
Greg
I paid EUR 50 incl. 19% VAT for my subframe to be blasted. Probldm is, it depemds on HOW much is to be removed and what material etc. Most places do it on a time base...
  #848
Old 10-11-2017, 03:02 AM
Daim's Avatar
I've bought a few more parts...
New rear cylinder head for the A6 compressor (a whopping €3.60 from Jaguar!!!)
New set of gaskets for the compressor from Jaguar
New set of uprated gaskets for the compressor from GM
New bearing for the compressor tensioner pulley
Some more screws and bolts
I'm not sure whether to replace the pulley and clutch with a new part or to remove the bearing and have the rusty bits blasted!? As they are balanced parts, removing rust will possibly cause an imbalance which can leak to the crankshaft of the compressor slowly warping/bending and end up with a nasty problem. The clutch seems okay. Slight bit or rust on the mating surface but that would rub away when it is all refitted and working again.
leo_denmark (10-11-2017)
  #849
Old 10-11-2017, 12:19 PM
Sylvain's Avatar
Changed oils,(engine, tranmission, differential, brakes), coolant, valve cover gasket , starter, timing chain tensioner and I am broken now
  #850
Old 10-11-2017, 09:10 PM
malc4d's Avatar
Trying to get an idea of how o operate the rear windows independently of the roof to work. Waiting for some relays to arrive..
  #851
Old 10-14-2017, 02:18 PM
macdoesit's Avatar
Banned
Advertised the pos for sale. Hopefully it will stay running long enough to unload.
  #852
Old 10-14-2017, 05:06 PM
89 Jacobra's Avatar
Received 1,190 Likes on 691 Posts
You sound about as happy with yours as I'am with mine. Obviously for different reasons, but still!
  #853
Old 10-14-2017, 07:19 PM
Thorsen's Avatar
Received 1,558 Likes on 670 Posts
Default CocoMats
I got my CocoMats in today.
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-20171014_191735.jpg
  #854
Old 10-17-2017, 04:22 AM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
Fixed (I hope) my passenger door lock today. It was acting up, and finally refused to lock at all with the remote fob, so I had to use the actual key. Checked some threads here on the forums, and, armed with those, my Big Green ROM, some Simple Green, shampoo (for slickening up the armrest), and some silicone grease, I removed the door card (helped a lot having done it a few times before for the speaker replacement), and tried to find what was wrong.
Nothing stood out--all the rods were in place, but the mechanism was still balking. So I cleaned it as well as I could, greased it, fiddled with it, pushed and pulled here and there, tried the key fob a few times, then the physical key in the door, and that seemed to do it. The doors now lock and unlock normally. In fact, I may be deluding myself, but they seem smoother, quicker--the passenger one always seemed half a second slower, but not now.
I hope I'm not deluding myself, and that the lock really is fixed. Absent an obvious cause, and having fixed it mainly by jiggery-pokery, I'm somewhat pessimistic....
  #855
Old 10-17-2017, 07:46 AM
RonaldP's Avatar
I have done the same thing on other cars where I cycled the lock linkage very fast for several minutes. It helps by reducing the total friction in the linkage the lock motor has to move.
Some Day, Some Day (10-17-2017)
  #856
Old 10-17-2017, 08:30 AM
I gather it's basically a case of not being used as much as the driver's side, though why that is a thing when the central locking opens everything, I am not entirely sure.... But yes, movement always helps.
  #857
Old 10-17-2017, 11:15 AM
Daim's Avatar
My passenger door lock was rusted inlocked as I got it. With lots of Güsol I managed to remove the rust and protect it from rusting again. Now the drivers side is stiffer... So there next
I paid for some more sandblasting today. Compressor case is now rustfree. A few dents in it but it is a compressor. I am sure I can knock them out!
  #858
Old 01-25-2018, 04:59 AM
Daim's Avatar
New compressor clutch for my Harrison A6... Though a part is still missing (coil). This is from a 1969 Chevy Bel Air
  #859
Old 01-28-2018, 06:59 PM
fat_cat's Avatar
I finally got my Jaguar running this weekend! Oh the joy to hear it run. Rebuilt the alternator, put it in and didnt crank. Put the battery charger on and still nothing. Found out a connector to the start relay was off. Plugged it in and fired up.
Also fixed my tach as it wasn't working either.
Daim (01-29-2018)
  #860
Old 02-02-2018, 10:36 AM
Daim's Avatar
The Harrison A6 air condition ng compressor is now gleaming like new! Fresh rubber, new clutch, new bearing, new modern double lip GM seal, ...
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
