What did you do to or buy for your XJ-S/XJS today?
Old 04-07-2018, 07:42 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
Originally Posted by eurolat
New brake pads and rotors for my xjs, my video unboxing
https://www.youtube.com/watch?v=iWyWrodLI5o&t=503s
Lovely, great choice. prise those rubber backing pieces off the pad metal though. They do no good and often cause the pad to jam in the calliper. (Just in case you were unaware) ensuring runout is under 3 thou is pretty important when fitting new discs.
EBC rotors and red stuff pads is what I have got, and they are brilliant. I will be interested to hear what the yellows are like, if you have a moment to post, after you have tried them.
eurolat (04-14-2018)
  #902
Old 04-09-2018, 02:56 PM
xjsv12's Avatar
Default A new friend from the United States.
Today I met Daniel. He came from America.
  #903
Old 04-09-2018, 06:12 PM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
Nice. A 1992 model? The white rear reflectors are that year only, I believe. The area under the bumper looks different to mine, however. Maybe I'm imagining it.
  #904
Old 04-09-2018, 08:57 PM
Time-Pilot's Avatar
I bought a cruise control pump, because mine just makes a terrible screeching noise, and a new actuator since the plastic nipple broke off when I removed the hose.
  #905
Old 04-12-2018, 10:40 AM
Anglicomarine0326's Avatar
Default First mild day in a very long time!
Washed, clay barred, waxed and cleaned my Dayton Wire Wheels. She runs perfect, and I will change the oil soon. This is my third XJS, a 91 convertible Classic Collection. Can’t wait for summer on Cape Cod.
  #906
Old 04-12-2018, 08:37 PM
brinny's Avatar
Very nice
  #907
Old 04-14-2018, 04:22 AM
eurolat's Avatar
ok, thanks for advise.
of course i will post, but it will be not so soon. because my suspension fully disassembled for restoration.
somebody can tell my what better grease to use for wheel bearing, u-joint, and etc (of suspensions). i can't decide between: shell gadus s3 v220c 2, mobil xhp 222 or kroon-oil HT Q9 ? or try to use synthetic lubricant (more expensive) : Mobilith SHC 220, Shell Gadus S5 V220, Mobil 1 synthetiс grease ?
how much I need grease to fully lubricate front wheel bearings + rear + u-joint + etc.. ? 3 x 400 gram tube will be enough? in workshop manual no information about it.
this week I received gaz shocks, my video :
  #908
Old 04-15-2018, 04:07 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
two new rear tires, 295-35-18 Don Rucker auto, Lakeway Texas.
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-wild-cat-burnout-006.jpg
  #909
Old 04-15-2018, 08:01 PM
89 Jacobra's Avatar
Received 1,168 Likes on 677 Posts
Originally Posted by 89 Jacobra
Another one to fix the first one! Pics coming soon.
Jack
Well Here's the story. I found my first XJS and decided to Lump it, as it had an engine fire, and repair costs were ridiculous. Then i found the under dash was also burnt, wiring, A/C, heater, etc. So I've been looking for several months, and found the virtual twin to mine, with one major difference. This one hasn't been on Fire! It even runs !!! All the pieces are there. Master cylinder, Interior, wiring harnesses, all the damaged stuff is there! YES!!! Now on to the Jacobra!
Jack
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-xjs-4-.jpg   What did you do to or buy for your XJ-S/XJS today?-xjs-5-.jpg   What did you do to or buy for your XJ-S/XJS today?-xjs-10-.jpg   What did you do to or buy for your XJ-S/XJS today?-xjs-6-.jpg   What did you do to or buy for your XJ-S/XJS today?-xjs-7-.jpg
  #910
Old 04-15-2018, 09:07 PM
Time-Pilot's Avatar
A/C - Fixed
CD Changer - Replaced and fixed
Cruise - Replaced pump and broken actuator, still dead, will work on this further.
Purge valve - Replaced
Quite the Sunday.
  #911
Old 04-16-2018, 03:37 AM
New harmonic damper finally arrived....
A reman version, so I have to post the old one back once the swap's been made, which will cost an appreciable percentage of the US$150 rebate, but better than nothing I guess. It's a very heavy, solid thing indeed.
  #912
Old 04-16-2018, 10:01 AM
jag-reflex's Avatar
Fixed the cruise control. Works perfectly now; no one more surprised than me
  #913
Old 04-16-2018, 10:15 AM
Time-Pilot's Avatar
What was it?
  #914
Old 04-16-2018, 10:41 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Finally, after an exhaustive search, installed front lower valence, front spoiler air damn, skid plate and front wheel well baffles...
Feeling like I can driver around now - a little more. Looking to get floor welded, as opposed to bolted in, asap. Saving my pennies for carpets from Pauls...
A.C., and a couple of leaks - and I'll be golden, lololololol...
Slowly but surely...
Greg in France (04-17-2018)
  #915
Old 04-16-2018, 10:59 AM
jag-reflex's Avatar
Originally Posted by Time-Pilot
What was it?
The inhibit switch at the base of the gear shift (just needed the actuator tweaked a bit) followed by the pot adjustments on the cruise amplifier..took a bit of flying up and down the freeway but there's worse ways to spend a Saturday. While I had the centre console apart I replaced the light bulbs with LED's with the idea that I'm not going in there again
  #916
Old 04-16-2018, 10:54 PM
JagXJS252's Avatar
I went on a little joy ride today after I gave her a wash and wax! Weather wasn't too bad so I figured why not.
I don;t mean to ask a stupid question but were most the XJS's autos? I feel like some people are talking about swapping out for a 5 speed..
  #917
Old 04-17-2018, 02:47 AM
All but about 176 very early V12 cars were autos. The 6 cylinder cars were offered with a choice of 5 speed manual or 4 speed auto boxes.
  #918
Old 04-17-2018, 06:23 AM
JigJag's Avatar
Full set of front suspension bushings ordered. She’s taken to shifting her steering rack around before she turns. Unsettling. All the bushings are worn out.
What else should I plan to do when I eventually man up and pull the subframe?
Why is it cold again? What happened to that lovely spring we were having?
  #919
Old 04-17-2018, 09:44 AM
NJ2003XJ8's Avatar
Could you share from where?
  #920
Old 04-17-2018, 10:35 AM
Look at the stub axles for wear grooves on the place the inner races bear on them, and check the bearings are OK. After that, I think as long as you have got all the wishbone, rack and the subframe bushes that is it. If the brakes are iffy, replace/rebuild the callipers and the discs and flexibles. If the master cylinder has not been replaced, good idea to do that.
Once the subframe is out, it is surprisingly easy yo get all the new bits on. The most hard is the lower wishbone fulcrum pin. buying two new ones is a good idea, they are not expensive. In my case I had to use an electric hacksaw to cut them in the tiny gap between the wishbone and the subframe. They would not knock out as the bushes cushion the hammer blows. The old bushes, with the cut pins in them, had to be burned out of the wishbone eyes! The pins rust into the subframe tubes a bit, but a drift and a big hammer moves them. Grease up the new ones with antiseize.
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
