What did you do to or buy for your XJ-S/XJS today?
#1062
Today I brought the battery from my newly acquired XJS over to my parents house to put it on the charger. The battery looks to be in good shape, but I tested it with a volt meter as the previous owner was having to jump it off his other vehicle the other day when I bought it, and it was reading 1.4 millivolts lol So I'm trying to charge it up to get it back up to snuff before taking it to a local parts store for them to test it and see if the battery checks out to be good or bad. If it doesn't have any charge, it won't even turn their battery testing machine on. This should take care of that, and maybe will save me from having to buy a battery. That'd just be more money to put towards brake or suspension parts.
#1063
Greg in France (09-19-2018)
#1064
I put it on the charger at 10 amps for about 3 or so hours and got it up to 13.5 or so. I had it tested on the way home at the parts store and they said by then it was reading about 12.5 volts but showing half of its cranking amps weren't registering. It was worth a shot to charge it and see if I could get anything out of it, no biggie if I have to buy a new battery.
#1065
#1066
I finally finished the welding on my inner wheelarch panels!
Just got to clean & paint all surface rust, spray cavity wax, buy all new front suspension bushes/balljoints/springs/shocks/nuts, reassemble front subframe & hubs, rebuild water pump, replace all hoses, flush cooling system, fit new front calipers, accumulator ball & thoroughly flush/bleed brakes, replace fuel hoses & flush old fuel out, sort the weeping seal on the fuel return to tank, & I may just about have a car I can at least drive out of the garage after nearly 2 years off the road.
I hate jobs that spiral
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
#1067
#1068
The following 2 users liked this post by Fla Steve:
89 Jacobra (09-23-2018),
treborefir (09-23-2018)
#1069
Finally had all front suspension mounts and bushings replaced with Superflex or OEM where poly was not available (as in Front subframe rear mounts) my god its so rigid and responsive. Upper bushings are OEM, as are the engine mounts and rear frame everything else front (and rear) now fitted with the same poly uprated parts used on the race cars.
Absolutely perfect.
Side note for anyone chasing steering wheel jutter or boat like handling. REPLACE YOUR SUB FRAME MOUNTS. These are overlooked too often.
Absolutely perfect.
warrjon (09-28-2018)
#1070
#1072
#1073
The following 2 users liked this post by Daim:
89 Jacobra (09-30-2018),
Doug (09-30-2018)
#1074
This is what I did yesterday and the day before, but was too busy to get on here and post. I replaced the hood struts and they work great. I also installed an antenna grommet, all parts from XKs Unlimited. I don't really see how the grommet is supposed to seal properly in the hole. I would figure it was like most grommets where there is a large enough gap between the top and bottom, or both sides, that the metal panel fit snugly into the gap but it doesn't seem to want to do anything along those lines with this grommet. At least I got it set in place with the antenna through it and the grommet angled correctly.
#1075
#1076
I'd say it is a more refined Miata. Softer springs, heavier steering, better shocks and a neat little turbo engine. Outside Fiat, inside Mazda. And I actually like the combination of both.
89 Jacobra (10-03-2018)
#1077
#1078
I got the horn to work! Only two days but hey, electrics are not my strong suit (slight understatement!) but with the help of the guys on here, sorted. Also, adjusted the idle speed and topped off the coolant after thermostat changes. Buoyed by my success, I had a go at getting the cassette player in the original 'Jaguar' head unit to work. It now does! It does take you back somewhat to be hunting around for cassettes and then playing them in the car... lacks a certain clarity ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Baby steps...
Baby steps...
#1079
#1080
fixing the fuel system. iv got the fuel system re-plumed to put the fuel pump in a much more ideal location and fuel lines re-routed power run to the new location and a redline 105gph fuel pump ordered
![](https://www.bigmacktrucks.com/applications/core/interface/imageproxy/imageproxy.php?img=https://i.ebayimg.com/images/g/fdMAAOSwBLlVSAV2/s-l500.jpg&key=ac06776813bede543a4783ce19b6bae42192ce78f695d8f17e4b7033963b45d8)
new airfilter assembly ordered to go with the next item
![](https://www.bigmacktrucks.com/applications/core/interface/imageproxy/imageproxy.php?img=https://i.ebayimg.com/images/g/9mIAAOSwEZdaBdWi/s-l500.jpg&key=82057f965323421d53ff8124d0c0211775588e04c58dc6e8118638cb719ad484)
and the part im most excited to see arrive
![](https://www.bigmacktrucks.com/applications/core/interface/imageproxy/imageproxy.php?img=https://www.jegs.com/images/photos/900/925/925-6503-1.jpg&key=3a7496e49d9aaab3536a3692a6305ef269f4fede7ab27ffcdf66bbfc8293f29d)
142 roots style supercharger.
