What did you do to or buy for your XJ-S/XJS today?
Old 05-18-2019, 07:55 AM
89 Jacobra's Avatar
Received 1,168 Likes on 677 Posts
Originally Posted by pablomonk
...today I bought some spare parts… LOL ...3 whole cars.... Now to get them home.
Yoooouuuuzzzzzaaaa That's some tore up Jaguars!!! I just thought my project was ambitious! Are you going to build one out of the 3 or just use for parts??? Good Luck.
Jack
The following 2 users liked this post by 89 Jacobra:
Spikepaga (05-31-2019), v1rok (07-15-2019)
  #1182
Old 05-23-2019, 07:39 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Actually on Tuesday... I installed the "Warrjon Chain Tensioner Plug". Awesome piece of kit! Thanks Warren!
  #1183
Old 05-25-2019, 04:22 AM
leo newbiggin's Avatar
i think the damage on the blue one will buff out
  #1184
Old 05-25-2019, 04:49 AM
Bez74's Avatar
And the maroon one is still registered (number plates on the boot)
  #1185
Old 05-30-2019, 11:07 AM
rgp's Avatar
rgp
rgp is offline
thought I would decorate the weather board of the garage with some engine plaque repair vinyl stickers I commissioned black and chrome and red 6lt versions excellent in every detail including the font and beautifully produced, used the red in the end but I still have loads available
pm me for details
  #1186
Old 05-31-2019, 07:28 PM
Time-Pilot's Avatar
New expansion valve since the o-rings were leaking on the top connections, and dryer of course. (Had to pull it to fix those may as well replace it)
Vacuum held steady all week at 28, so tomorrow I'll recharge.
JayJagJay (06-07-2019)
  #1187
Old 05-31-2019, 07:51 PM
Padre's Avatar
Brought it home.
1993 XJS Convertible, British Racing Green (EDIT: it's actually HFB, Brooklands Green). 81,000 miles. Great shape all around.
I sold my '94 XJS Coupe (138k+ miles) and my '89 Canadian XJ12 (grey market). Less time to work on those projects and I wanted a driver.. This one will do nicely.
Padre
The following 3 users liked this post by Padre:
Spikepaga (06-08-2019), Timeisrelative (05-31-2019), v1rok (07-15-2019)
  #1188
Old 05-31-2019, 10:05 PM
Timeisrelative's Avatar
Gee looks exactly like mine, only in a lot nicer shape! Lol! I did my starter today!
  #1189
Old 05-31-2019, 10:40 PM
XJ6Paul's Avatar
Originally Posted by Padre
Brought it home.
1993 XJS Convertible, British Racing Green. 81,000 miles. Great shape all around.
Padre
Padre,
Congratulations, looks great and a great color. Is that a barley color interior?
Sorry to hear you sold your SIII V12. Did you put many miles on it while you owned it?
  #1190
Old 06-01-2019, 07:02 AM
rgp's Avatar
rgp
rgp is offline
fitted an ordinary domestic rad bleed tap to my rad, so this one wont fall down like some I have known have.
1984 v12 H.E.
  #1191
Old 06-01-2019, 12:05 PM
Padre's Avatar
Originally Posted by XJ6Paul
Padre,
Alas, no. The bad right-side gas tank was an issue. Really couldn't drive it far. Overall, nice car, but needed some work to be a driver. Just didn't have the time to do that. And with the Coupe and the XJ12 just sitting there, I thought about it a lot and decided as fun as tinkering with them was, I really wanted a driver.
The interior is the AFW code Barley. And just realized the exterior is HFB, Brooklands Green.
And the immaculate engine:
Padre
Timeisrelative (06-01-2019)
  #1192
Old 06-01-2019, 01:03 PM
rgp's Avatar
rgp
rgp is offline
I have never seen a 6 pot in one of these in memory it looks a bit empty under the bonnet to me, did they sacrificed cylinders for relays, lol
  #1193
Old 06-01-2019, 08:09 PM
Bez74's Avatar
That is a real nice car Padre - even down to the plastic under your feet
Steve
rgp (06-05-2019)
  #1194
Old 06-05-2019, 06:33 AM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
A very simple fix today--finally replaced the cruise control bush. On my last major road trip I had realised that the reason the cruise control didn't work was because the grommet holding the rod had failed, allowing the rod to pull loose from the socket thing. David Manners had the part, but was going to charge several times what it was worth to post. Even domestically to family in the UK would be more than the part cost! But a bit later I needed to place a large order for redoing the front wishbone bushes, so tossed in two of these--one spare.
Hmmm. Should this be like this?
Wow, that's some serious discolouration....
And there it is. Also polished the rod while I had it out, and put lots of CRC on the thread so it won't be as hard to get out.
A very simple operation, but satisfying nonetheless. I have been doing/getting done a few other things as well--new "XJS" badge for the rear, new growler hub caps, and a respray of the roof and boot as they were looking rather the worse for wear. Apparently the roof at least had already been resprayed once. Might be why it was in notably worse condition than the bonnet. And today I also experimented with redyeing the driver's seat. Needs another coat or two.
Greg in France (06-05-2019)
  #1195
Old 06-05-2019, 12:39 PM
bhill's Avatar
Default Returned to Jaguar Forums.com
Been away from forum for several months concentrating on new business venture which looks now as though it will probably succeed.
Problem is this: In August I purchased a "91 XJS convertible with reasonably decent appearance and okay top.
So far I have replaced all subframe mounts, all fuel hoses, AC compressor and receiver/dryer, all new Pirelli P600 (($1200), rebuilt PCB for cruise control, Serviced cooling system (including rodding radiator, new thermostats, caps, and all hoses), new idle/auxillary valve, new plugs, new injector heat shields, new rear mufflers, new wiper motor assembly, new tach, several interior light fixtures, flushed TH400 tranny and replaced pan gasket, rebuilt steering rack mount, aligned all wheels and steering, replaced defective brake system accumulator, replaced miscellaneous trim pieces, replaced rubber front bumper, repaired speedometer, replaced missing hood boot, and several interior switches. I still haven't been able to make the bonnet easy to latch, but that's a minor worry.
At present the vehicle runs better than any other Jaguar I've ever owned (or driven) and I'm quite happy with it. Now it's time for some cosmetic work, and the first item is the carpeting covering the compartment behind the seats, which looks as though it has a bad case of mange.
I have had no problem sourcing parts (although I had to use heat shields from Mercedes-Jag won't sell them independent of the injectors), but I cannot seem to contact anyone who deals in the material used in the carpeting.
My question is this: Can anyone recommend a source?
Meanwhile, I've got about $23K tied up in a $12-14K car, so I'll have to make up the difference in sheer driving pleasure.
Thanks in advance.
Bill
  #1196
Old 06-07-2019, 10:37 AM
Daim's Avatar
Forgot to upload the pics
The following 2 users liked this post by Daim:
Bez74 (06-08-2019), Mike1610 (06-07-2019)
  #1197
Old 06-07-2019, 10:49 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
I AM SOOOOOOO JEALOUS. The expansion valve attempted scared the hell out of me and i gave up. Still trying to get my AC right... Sid have success with the Porsche 928 tho...
Good work, Man.
  #1198
Old 06-07-2019, 11:01 AM
JayJagJay's Avatar
Got some new seat covers and carpets are on the way.
About the seats,,,, don't ask, lololol... OMG
Actually, it's going ok...
Just out of the monster
After opening and lubing. Pump and bladder work!
Not strapped down, at all,, only pulled over the frame.
Got heat???
Ready to be fitted...
  #1199
Old 06-07-2019, 01:13 PM
leo_denmark's Avatar
So far I have replaced all subframe mounts, all fuel hoses, AC compressor and receiver/dryer, all new Pirelli P600 (($1200)....
Bill
New P600 ? What size ? Where did you find them ? I need 15” !
  #1200
Old 06-07-2019, 03:17 PM
JayJagJay's Avatar
Thanks in advance.
Bill
Bill,,, Paul's Jag in Florida...
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
