What did you do to or buy for your XJ-S/XJS today?
Old 11-12-2019, 05:27 AM
pablomonk's Avatar
Sold her on. Not enough time to enjoy and keep her running right. Only did 400 odd miles in the last year. Not enough for a V12to stay healthy.
Now to find homes for the spares clogging up my garage… think I may have overdone it as usual. LOL
Now to find homes for the spares clogging up my garage...
Flint Ironstag (11-20-2019)
  #1282
Old 11-14-2019, 11:32 AM
egovreau's Avatar
Replaced the bulb failure module, so I have brake lights now. I did not realize that the key needed to be on for them to work. Just a bit frustrating as I know that the middle brake light worked before and it wasn't dependent on the module to work. Probably the first car I've owned that does that.
I can safely drive it on the street now!
Moved on to removing the driver's door card to figure out why I can't open it from the outside. I think it's broken somewhere in the handle, as nothing was obvious. I have to see if I have a replacement in the goodie box that came with the car.
Lastly, went in search of the power windows thermal breaker to address the fact neither of the windows work. It didn't see it where I expected to so the search continues. Unless I was looking right at it and it didn't look like I expected it to.
  #1283
Old 11-14-2019, 02:37 PM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
egovreau,
I suspect the auxiliary brake light is not wired through the bulb failure module because those lights were only fitted in places such as the US that demanded it. Therefore, Jaguar probably just used a standard module on all XJSs but naturally couldn't run the additional US light through it.
As regards the thermal cut-out switch, have a look at Jaguar's parts website here to see it's location and image:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Paul
  #1284
Old 11-15-2019, 12:50 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
Originally Posted by ptjs1
egovreau,
Paul
Excellent point Paul. I have a third brake light, an lovely LED long shaped one, and it never occurred to me that it might interfere with the bulb-out warning. I shall go out and remove a brake light bulb and check later! Of course, extra load would not trigger the device, but it might mean when a single bulb (of the three) failed it would not trigger it.
  #1285
Old 11-15-2019, 10:48 AM
fishbait1's Avatar
Default dash mount phone caddy
just got it from China. 6 weeks to get it. $12 approx. plastic with a plastic spring clip. a conversation piece but fun and it actually holds the phone well. i'll see how long it holds up.
The following 2 users liked this post by fishbait1:
Dukejag (11-17-2019), egovreau (11-16-2019)
  #1286
Old 11-16-2019, 11:14 AM
jerry_hoback's Avatar
Received 1,149 Likes on 806 Posts
Went to the BMV and got title and plate done . The gal said Historic plates are cheaper (?) and the CEO said cheap plates.....
  #1287
Old 11-16-2019, 07:42 PM
egovreau's Avatar
egovreau,
Paul
Hey, thanks. I think I've found it, but it's not mounted exactly in the same place as what the line drawing indicated, but it's within a couple of inches. Funny thing, though...I was under the impression that it can be reset. This one doesn't appear to be the case.
Yeah, the top brake light is not wired through the module. I have the wiring diagrams for my year which confirms it. I'm tempted to see if I can figure out how the module works to see if I can replicate it in the event the 'new' one fails.
  #1288
Old 11-16-2019, 09:25 PM
Doug's Avatar
Received 10,874 Likes on 7,151 Posts
You can replace it with a fuse or a resetable circuit breaker
  #1289
Old 11-17-2019, 01:51 AM
egovreau's Avatar
Good point. Any idea what it's rated for? I just checked the electrical diagram, but it doesn't seem to give an amperage rating.
  #1290
Old 11-17-2019, 02:12 AM
The brake light failure unit has no reset or similar. But it can be carefully taken apart and fixed, see the Great Palm's book on how to do it.
  #1291
Old 11-17-2019, 06:51 AM
Doug's Avatar
Not sure, but 30 amp is common in power window circuits and oughta do the trick.
  #1292
Old 11-17-2019, 03:30 PM
egovreau's Avatar
That post was about the thermal circuit breaker for the power windows.
But it is encouraging that the brake bulb failure module can be fixed.
  #1293
Old 11-18-2019, 07:31 AM
malc4d's Avatar
On my '92 MY the window TB is under the right side panel near the fuse panel.
  #1294
Old 11-19-2019, 06:37 PM
anyoldiron's Avatar
Banned
Default let there be light
,,,,,,,,,,,,,,and there was courtesy of SNG Barrett
Timeisrelative (11-20-2019)
  #1295
Old 11-20-2019, 09:07 PM
egovreau's Avatar
Awesome. Thanks! I'll start looking into swapping it out. Although, I suppose I should at least check to see if it's blown first.
  #1296
Old 11-24-2019, 06:14 PM
Got it up onto jackstands and slid under to do some preliminary checkout. It is remarkably solid and I think most of the deterioration has happened in the last year while it was outside. the P.O. said it had been inside prior to then. Drained fuel tank.
  #1297
Old 11-24-2019, 09:46 PM
ralphwg's Avatar
Received 1,209 Likes on 915 Posts
Tomorrow my 94 XJS vert goes to the shop for a front bumper cover replacement install.
  #1298
Old 11-26-2019, 09:36 PM
malc4d's Avatar
Changed out the rubber bushings on the throttles ….Went surprisingly easier that I thought it would.
Timeisrelative (11-27-2019)
  #1299
Old 11-29-2019, 05:11 AM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
These arrived from Amazon today. Pity the red will be almost totally invisible. I could almost change these myself, save for worrying about what happened when Orangeblossom tried it and wrecked his ABS by getting dirty brake fluid pushed back up from not undoing the bleed nipples and/or clamping the hose.
However, I'm wondering if I should also replace the front brake rotors as well. The port side one appears to have a deep-ish groove in it.
  #1300
Old 12-05-2019, 02:50 AM
stran0020's Avatar
can you tell me where you bought those bushings? Bought of mine have no rubber on them
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
