What did you do to or buy for your XJ-S/XJS today?
Old 03-10-2021, 03:34 AM
rgp's Avatar
rgp
rgp is offline
Originally Posted by FinCat
Hi. I am there at the moment. In my case, both, LH/RH channels were badly corroded, top one is almost completely gone. Lower ones are still serviceable but needs some puffing.
Just separated them and started to make new top channels.
Found out massive amount of silicone, which clearly used for sealing water leaks after channels corroded and became leaky. But, in my case not that much sealant below channel assembly. Maybe someone tried to seal something on yours, but never put enough as bead seems to be still far away from channel??
Almost finished fuel tank/fuel hoses on trunk area. Everything installed back, with brand new 2-layer hoses and after smell test i was happy... no fuel smell anymore. Nothing leaked there at the beginning, but old original hoses seems to let smell thru. Rear screen installed too.
Have you pressurised it yet?
  #1542
Old 03-10-2021, 04:56 AM
FinCat's Avatar
Yes, couple of times and few times started to idle. (Car is parked in carage)
rgp (03-10-2021)
  #1543
Old 03-11-2021, 07:42 PM
egovreau's Avatar
I haven't made it back to working on the door rubber yet. I was waiting for what new parts I could get. I also have to drill a few screws that sheared off and source all new ones as they're all corroded junk.
Also decided to go after the trunk and the fuel lines. Lots more corrosion and will need to get a new trunk seal. Also noticed that the trunk floor has been pushed in a little. Might get to put those body tools I bought to good use.
This is just criminal...
The following 2 users liked this post by egovreau:
rgp (03-12-2021), Timeisrelative (03-21-2021)
  #1544
Old 03-13-2021, 02:30 AM
FinCat's Avatar
Looks that you have things to do on trunk area... I would pull the tank and refresh it now, also worth to check that rivet under the tank... as mentioned here and there by experts.
My trunk floor is dented inwards too, just slightly, under spare wheel area. Think someone in the past used jack on wrong place. Smooth contour and no paint damage-> no action needed.
That spare wheel... ouch.
  #1545
Old 03-13-2021, 11:03 AM
fried_hippies's Avatar
I just did that exact damage to the boot floor :-(
Rear suspension off. Got a big ****-off trolley jack in under the raised car just fine, pumped up high to a beam across the well where the subframe goes. Lowered the car gradually onto a dolly. As the jack arm angle changed, it punched the boot up. Silently.
Fortunately, the bodywork and paint is yet to be done. Glad to see I'm not the only idiot ;-)
Moral of the story, when jacking things, stop regularly to inspect your clearances!
  #1546
Old 03-14-2021, 07:49 PM
jerry_hoback's Avatar
Received 1,149 Likes on 806 Posts
Ordered 4 brake calipers, front wheel bearings, and steering rack boots to accompany the previously purchased brake pads, rotors, shocks and brake hoses among other stuff..... renovations continue.
Greg in France (03-15-2021)
  #1547
Old 03-15-2021, 11:29 AM
rgp's Avatar
rgp
rgp is offline
Fitted later illuminated sun visors in my 1984 HE some time ago and got S type covers to cover the screws, after covering them in the same leather as the visors they fit quite nicely.
  #1548
Old 03-16-2021, 02:35 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
Rex
How did you run the power to the facelift visors?
  #1549
Old 03-16-2021, 02:50 AM
rgp's Avatar
rgp
rgp is offline
Rex
I removed the interior light and extended the wiring to each visor, and made up a cover to fit over the hole left where the old one had been.
turned off for picture
The following 2 users liked this post by rgp:
Geewhite (03-29-2021), Timeisrelative (03-21-2021)
  #1550
Old 03-16-2021, 09:04 AM
Rex
how does the current get to the actual visor?
  #1551
Old 03-16-2021, 11:04 AM
malc4d's Avatar
When l added this to my '91 convertible. l connected to the interior light circuit and ran the wires up each A post to the visor.
Anyone tell me how to stop the 2 rear interior light from falling out of the side trim ??
  #1552
Old 03-16-2021, 11:10 AM
rgp's Avatar
rgp
rgp is offline
I stopped them by carefully bending out the metal tabs with a small electricians screw driver
malc4d (03-16-2021)
  #1553
Old 03-16-2021, 11:13 AM
rgp's Avatar
rgp
rgp is offline
Rex
Same wire that works the interior light. It's all there. I did purchase all new from jdht sent them straight to Aldridge trimming to cover in isis blue leather and jdht included the short harness with correct plugs already. Just connected to old int light wire.approx 6 years ago.
  #1554
Old 03-21-2021, 06:46 PM
egovreau's Avatar
Well, I get a pass, as the car was like that when given to me.
  #1555
Old 03-21-2021, 06:48 PM
egovreau's Avatar
Based on what I can find, would that be the rivet under the fuel tank that tends to wear a hole through the bottom of the tank? I'm already thinking about removing the tank, so I'll inspect for it.
Gracias!
  #1556
Old 03-22-2021, 01:57 AM
Gracias!
Yes, that's the one. Just drill it out, nothing else needed to be done.
  #1557
Old 03-23-2021, 01:32 PM
valkrior's Avatar
Smile 1994 XJS V12 Cold Air Intake upgrade
Hi, I just finished the installation of a new, custom cold air intake upgrade on my '94. Given the stock intake necks down to 1.5 inches, but the throttle-body opening is 3", I used 3" as the minimum area throughout. I printed all these parts off my 3-D printer. I included a canister, K&N style filter (inside the metal can that you see in the pictures), which doubles the filter surface area of the stock filter. I also designed new intake mouths (on top of the radiator) to ensure no restrictions on the 3" area. I am super pumped with the results. The car sounds different - with the small intakes, it sounded a bit like a shop-vac when it was started, because its sucking so much air through that tiny hose; now its actually quieter
The car was noticeably more responsive, too. I have a spot where if I floor the car in Sport mode, I can just hit 60MPH between the intersection and a bridge. With this new intake, I hit 65MPH!!! - no joke. Over the next couple weeks, I'll monitor the MPGs to see if there is a measurable change there too. One of the best car mods I have done lately.
The following 3 users liked this post by valkrior:
Geewhite (03-29-2021), Greg in France (03-24-2021), rgp (03-24-2021)
  #1558
Old 03-24-2021, 07:56 AM
Ooh wow @valkrior
How does that affect the intake noise? Do you get more snarl, or less?
I've been thinking about intakes but taking AJ6 Engineering's writings on the topic as my starting point - they offer a hi-flow filter that goes in the stock air box. (They have several pages on air and exhaust flow, here's one for starters: How Things Are Done | aj6 engineering )
  #1559
Old 03-24-2021, 08:48 AM
VancouverXJ6's Avatar
What are the mini filters for?
  #1560
Old 03-24-2021, 09:24 AM
Rescue119's Avatar
My guess would be dizzy breather filter etc. Any airline that just sits open in the bay.
Or airline that went into the stock air box.
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
