What did you do to or buy for your XJ-S/XJS today?
Old 12-16-2014, 09:55 PM
Jonathan-W's Avatar
Lets see
ASI PROCOOL Jaguar XJS V12 silicone radiator heater Hose kit BLUE
5 PACK 12V DC 30A/40A Relay & Socket SPDT Bosch Style
JAGUAR XJS DASH LIGHT DIMMER SWITCH RELAY DAC10512
Genuine Freshwater White Pearl Necklace Bracelet & Earring Set (for the wife to wear while riding shotgun)
(need to buy scarfs... for their hair...)
Last edited by Jonathan-W; 12-16-2014 at 10:08 PM. Reason: left of something / spelling
  #142
Old 12-17-2014, 11:33 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
I turned this:
Into this:
Another step closer to the start Maybe 2014?
  #143
Old 12-18-2014, 09:54 PM
Dleit53's Avatar
Got the wife a NOS Lucas hall effect trigger board for her 78 XJS. I'm going to wrap it up for Christmas. Won't she be excited!
  #144
Old 12-28-2014, 09:01 PM
ShaneClara's Avatar
Cool Applied temporary Solutions to My '88 XJSC
Installed my new/used Delanaire Mk-III unit and blowers to no avail. So I tracked the wiring down and jumped some plugs to have heat and blowers for now. Not pictured is the switch I put between the high speed relay and the Ign. power supply.
Since the gremlins are still pretty active in my car. I awoke this morning to a dead battery. Seems the Interior light timer decided to come on overnight and drained the battery flat. Figuring i didn't need a timer anyway I jumped the connections with a 10a fuse and now i have normal operating interior lights.
Attached Thumbnails What did you do to or buy for your XJ-S/XJS today?-heater-bypass-route.jpg   What did you do to or buy for your XJ-S/XJS today?-jaguar-xjsc-interior-light-timer-bypass.jpg
Mkii250 (01-03-2015)
  #145
Old 12-31-2014, 10:36 AM
Brake buster's Avatar
got 20ltr of Dexron III delivered
just need to get some into the car now
BB
  #146
Old 12-31-2014, 10:59 AM
Daim's Avatar
1 can of matte black spray paint.
Maybe the Iron Lady would look good in a matte black dress?
  #147
Old 12-31-2014, 01:49 PM
The new convertible top and headliner just arrived for my '90.
Now the fun of installation begins!
Mark
  #148
Old 01-02-2015, 10:50 PM
gregh's Avatar
Dsetter, How did you access the multi-pins connectors for the heatwer control? -Where would I start to find them?
Thanks,
-Greg
  #149
Old 01-02-2015, 11:04 PM
gregh's Avatar
Flint IronStag, My original oil spinner cap on my '89 is black, however I also bought the complete drivetrain from a '91 XJS, and it had a RED spin-on filler cap, so I now use it, simply because it catches my eye easier.
-Greg
Flint Ironstag (01-04-2015)
  #150
Old 01-02-2015, 11:17 PM
gregh's Avatar
Daim, Interesting little tidbit, Here in Canada, vehicles get licensed yearly based on their weight- - and we are in the Metric system now.
Obviously, over the years, somebody entered the 2200kg weight as 2200 lbs, and Dept. Motor Vehicles charges me a fee of $72.00CDN. Will I tell them????? - I'll take my chances and plead ignorant if asked.
-Greg
  #151
Old 01-03-2015, 04:32 AM
Daim's Avatar
-Greg
I wish it was like that here. Displacement +emissionsclass = taxation of around €1200/year
  #152
Old 01-03-2015, 09:16 AM
Greg in France's Avatar
Received 9,258 Likes on 5,438 Posts
Warmed up the car in the garage today to give the aircon compressor a go, and to have a general XJS fix. Noticed that the air bleed arrangement pipe from the crosspipe centre fill spout take-off to the RHS radtop banjo and thin radtop cross pipe was not getting warm.
This indicating the small steel tube exiting the crosspipe fill spout was blocked.When the engine cooled off I removed the rubber pipe from the steel tube takeoff, and the cap on the spout (a solid non-valved cap in my case). Air in the spout which there should not be ideally. Blew through the rubber pipe into the fill spout and it was blocked, sucked, same thing. There is a non-return vale arrangement in this tube that prevents water going into the spout from the radtop bleed arrangement. This is still available from Jaguar, and fits into the end of the rubber pipe that connects to the crosspipe spout takeoff pipe. Part number EAC4126
Metal takeoff pipe from the fill spout was completely blocked. I had ensured it was free when I rebuilt 4 years ago. Coolant regularly changed, so how it blocked up I do not know. So I drilled out the blockage, refitted a new rubber pipe, pushed the non-return valve into the rubber pipe to clear the steel takeoff pipe and allow enough free rubber pipe to be clamped up to the steel takeoff. Then checked the non return valve was working by sucking/blowing. Did it all up, topped up the spout and started the car.
In no time the tube was getting warm, indicating the crosspipe bleed arrangement was working again. So well worth checking this function from time to time. If it is working correctly, the takeoff pipe should get warm, not hot but noticeably warm, well before the thermostats open. Once they open, the whole lot gets so hot you cannot tell.
greg
Jonathan-W (01-05-2015)
  #153
Old 01-03-2015, 09:48 AM
dsetter's Avatar
Thanks,
-Greg
Hi Greg
The controller is attached to the right hand side of the heater. You need to remove the knee bolster and the air duct outlet and then the heater controller CPU is the small black grand piano shaped module must behind the fan speed control knob. There are 3 screws that hold it in. 2 are easy to get to. I think the 3rd requires removal of the trip computer.
  #154
Old 01-04-2015, 05:07 AM
Steve M's Avatar
Received 2,996 Likes on 1,691 Posts
Original, boxed Marelli rotor arm arrived yesterday; now to find a cap.
  #155
Old 01-04-2015, 05:21 AM
Hi Steve
i have several genuine Marelli caps , some new some used , pm me , or i will bring to Kemble if your going ?
  #156
Old 01-04-2015, 08:28 AM
Steve M's Avatar
Thanks BB, I'll try and make Kemble but it depends on work.
  #157
Old 01-12-2015, 02:14 PM
Daim's Avatar
I bought a new friend for my XJ-S
[img]https://farm8.staticflickr.com/7534/16263662371_6398c36616_b.jpg[/img
Flint Ironstag (01-12-2015)
  #158
Old 01-12-2015, 08:22 PM
Flint Ironstag's Avatar
Black interiors are the business. Are those clothe inserts in the seats? Congrats on the new addition!
Daim (01-13-2015)
  #159
Old 01-13-2015, 01:42 PM
Daim's Avatar
Yes, they are cloth inserts but not a nasty cloth. Feels like alcantara...
Black interiors are my favorite. The headliner is "beigy-grey" so that will be replaced with black
Black on black on black
Flint Ironstag (01-14-2015)
  #160
Old 01-13-2015, 06:27 PM
Bc xj's Avatar
Nice car. I'll bet they'll be best of friends
Daim (01-14-2015)
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
