What did you do to or buy for your XJ-S/XJS today?
Old 05-21-2022, 02:55 AM
rgp's Avatar
rgp
rgp is offline
Use a Dremel, Rex?
Good idea Greg
  #1662
Old 05-23-2022, 01:23 PM
BenKenobi's Avatar
I absolutely could not resist - this is what some may regard as a sad purchase but in all my years messing with cars I don't think I have ever seen a hardback user manual.
The following 4 users liked this post by BenKenobi:
arcticsilvere39 (10-30-2022), csbush (07-23-2022), egovreau (05-23-2022), rgp (05-23-2022)
  #1663
Old 07-14-2022, 02:47 PM
leo_denmark's Avatar
New rubber for my high pressure AC hose. Looking forward to have a cool ride again…
The following 2 users liked this post by leo_denmark:
eurolat (07-14-2022), Greg in France (07-15-2022)
  #1664
Old 07-22-2022, 03:06 AM
Shaneb's Avatar
Maybe not quite today, but almost finished by front of engine tidy up, all new rads, fans and wiring , and conversion back fro prev single pass and ford fans that I used to have.
The following 4 users liked this post by Shaneb:
eurolat (07-22-2022), Grant Francis (07-22-2022), Greg in France (07-22-2022), LnrB (07-22-2022)
  #1665
Old 07-22-2022, 03:11 AM
Greg in France's Avatar
Received 9,342 Likes on 5,478 Posts
Where did those lovely-looking intakes come from?
What intake filtration have you got in that setup?
I love the radiator system and header, I have done something similar.
  #1666
Old 07-22-2022, 03:36 AM
Shaneb's Avatar
made the intakes about 14 years ago, just standard manifold with bell mouth type modification inside, rolled ally tube and misc plated all fitted together and welded to the split open original together to form this shape.
Cone air filters are in the inner front guards, not easy to get to to change but, how often do you change them.
- Shane
The following 3 users liked this post by Shaneb:
  #1667
Old 07-22-2022, 03:40 AM
Beautiful work.
Do you reckon the intake mods, bell mouths on the runners and all, has made a difference?
  #1668
Old 07-22-2022, 05:55 AM
Shaneb's Avatar
Beautiful work.
yup, dynoed over 4 diff stages.
1) 150kw stock 6l on with th400 trans 2.88 diff, (2005)
2) 170kw as above but with bell mouthed aj6 plenums end enlargedthrottles, va spiteri headers and autronic ecu.
3) 188kw as above but with manual transmission.
4) 205kw as above but large modified plenums as per above pics (2008)
next stage was to be larger motor flatheads etc etc but never got there
- shane
The following 2 users liked this post by Shaneb:
Greg in France (07-22-2022), Thorsen (07-22-2022)
  #1669
Old 07-22-2022, 07:13 AM
Thanks for posting this data, and congratulations for getting it. Interesting that it was 18KW = 24 BHP gained by the chnage to a manual box, I had though that it might be a bit more. Mind you, lots of weight saved too.
  #1670
Old 07-22-2022, 08:23 PM
EcbJag's Avatar
Beautiful work, it looks like you relocated the A/C compressor to the smog pump's location on US spec cars. I imagine this would help keep temps in "the V" quite a bit cooler. Is it the OE compressor with a custom bracket?
  #1671
Old 07-23-2022, 12:21 AM
Shaneb's Avatar
New sanden compressor, new bracket but very straight forward. Hardest thing was that i had to modify the thermostat housing so it did not foul the compressor
pics below
EcbJag (07-26-2022), Greg in France (07-23-2022), ptjs1 (07-23-2022)
  #1672
Old 07-23-2022, 09:32 AM
rgp's Avatar
rgp
rgp is offline
Default C46179
Having accumulated 4 heater fan quad relay relay C46179 I have found out a lot about them and I rebuilt them. Most of the prob are caused by careless dismantleing and ageing. I have found on them all it can be reversed. If anyone has an old faulty one I can work an exchange on it..prividing yours is servicable
  #1673
Old 07-23-2022, 03:48 PM
Brake buster's Avatar
looked at it having fun on Facebook, as someone else owns her now :-(
BB
  #1674
Old 10-07-2022, 08:23 AM
rgp's Avatar
rgp
rgp is offline
THOUGHT I WOULD MAKE LIFE EASIER FOR FUTURE owners and service personnel by fitting the relovent usa vacuum stickers to my bonnet insulation support
finisher
Greg in France (10-07-2022)
  #1675
Old 10-13-2022, 05:02 AM
purrkittypurr's Avatar
[QUOTE=Shaneb;2547941]New sanden compressor, new bracket but very straight forward. Hardest thing was that i had to modify the thermostat housing so it did not foul the compressor
I notice you have deleted the fill/purge spout on the cross over pipe. How do you get the air out with the stats closed? Unless you deleted the stats or modified the jiggler. I'm considering going back to stock rad config too.
  #1676
Old 10-18-2022, 04:10 PM
mike_D's Avatar
Default got new floor mats for the XJS
BenKenobi (10-18-2022)
  #1677
Old 10-18-2022, 04:14 PM
BenKenobi's Avatar
Pretty sharp - I like those, very interesting choice too, many go for wool or tufted mats, carpets and seats are similar to mine and yet that color doesn't look too bad.
mike_D (10-20-2022)
  #1678
Old 10-18-2022, 04:56 PM
Thorsen's Avatar
Received 1,559 Likes on 671 Posts
Where did you get those from??
  #1679
Old 10-20-2022, 09:51 AM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Holy SMOKES!!!
I have so so so so many questions...
It just wouldn't be right here...
Can you PLEASE talk about those intake manifolds a little bit more. What ever you'd like to offer will do just fine!
I read your reply to Greg but didn't quite understand
  #1680
Old 10-20-2022, 10:51 AM
mike_D's Avatar
I found a guy via a Facebook Jag group that makes custom floor mats. He is in Turkey. Here is the link:
Facebook Post
Quick Reply: What did you do to or buy for your XJ-S/XJS today?
