What is this hose?
Received 10,871 Likes
I'm guessing it's one of the hoses to the distributor vent system
https://parts.jaguarlandroverclassic.../brand/jaguar/
The following 2 users liked this post by Doug:
Grant Francis (06-07-2020),
Greg in France (06-08-2020)
I think Doug is correct. It looks like the plastic piece is the one that joins the top dizzy vent hose to the AAV/manifold hose, its barbed bit having mostly broken off. No 6 in this diagram Doug posted;
IF it is a Marelli, it isn't part of the dizzy vent system, as the connector on the AAV hose take off is brass. The hose routes then to another metal fitting on the dizzy. The other side is from the wing to the dizzy. In the wing is a plastic air filter. Again, no 90° fitting...
EDIT:
seems the brass fitting isn't standard then...
EDIT:
Yeah, that sounds about right. Kind of a cheesy implementation. I'll have to see if I can come up with something a little neater.
tbird6
06-11-2013 12:34 PM
