What if I forget to put the air pump back on?
I've got the air pump off so I can work on bringing cold air through a hole I'm about to cut into the engine compartment. If I were to forget to re-install the air pump (I'd probably just take the belt off for now, since I'm not likely to need that A/C to work anytime soon), should I plug to pipe at the center of the photo?
What other connections should be plugged?
Thanks,
John
1987 XJS V12, (supposedly) 62,000 miles.
Thanks,
John
BrentGardner
28
04-26-2024 03:08 AM
