What is the Main Advantage or replacing the Mechanical Fan with an Electric Fan?
I certainly would not replace a perfectly good mechanical fan with electric. I did replace mine because the viscous clutch was bad and my electric fans cost less than a new clutch.
All electric fans are not equal (the reason I purchased OEM for fans not aftermarket). The shrouding around the fan is important and should be circular as close to the blade tips as possible without touching, this reduced washoff which is where the air flies off the tip of the blade, Like new Jets have winglets.
Blade profile is important and some of the latest have V cuts in the trailing edge which cuts down on noise, we can thank the Owl for this one.
So if you do need to replace the fans look at OEM units, the manufacturers spend lots of $$$ to design these.
100% agree, if you can find an OEM fan with a frame that will drop in (just as Grant and others in Oz have done) it is both cheapest and best. But Spal aftermarket fans are specified OEM by many manufacturers (eg Ferrari and other high-end makes) and Pacet also very good, in fairness. It is the too-cheap-to-be-true ones that you need to avoid.
Greg
The following 4 users liked this post by Greg in France:
Received 10,979 Likes
Welcome to Jag-lovers - Members Photo Viewing Page
orangeblossom (04-27-2016)
The following 2 users liked this post by Doug:
Grant Francis (04-28-2016),
Received 2,399 Likes
I don't know how well they compared in terms of cooling. But, they're not break-proof, if that's what you're driving at
Cheers for Posting those Pics, though at the same time quite unsettling when you realise what can happen.
I'll get one of the New Plastic Type and include it in the 'Pre Flight Checks' that I do before I go out.
The Chris X
04-25-2016 06:06 PM
Griff79
04-25-2016 05:38 PM
