what is this part?
Is that the EGR vac?
Ah sorry about that Rama, EGR vac yes. Can't see how it helps performance but apparently it is used to recycle unburnt fuel back into the system rather than dumping it.
My 92 does not have this system, one less thing to go wrong.
I do suppose that it should be attached with something more than bandage and laundry wire.
Someone will be able to offer a better explanation, I hope.
Yup its the EGR. It recirculates unburnt gases from the manifold for better burning of spent fuel, and emissions gubbins. But these do tend to get dirty and it will be most noticeable at idle under 800 rpm. To make your engine idle like its fresh from the factory you can clean the EGR, because it builds up a lot of carbon inside and restricts flow, thus rough idle. ![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
You have to remove it to clean it.
For anyone who wants to know the steps on cleaning the EGR its here:
1. Fill the EGR valve opening with carbon cleaner. Fill up the valve until the cleaner comes out of the top of the valve opening.
2. Let the valve soak in carbon cleaner for at least eight hours. This will loosen the carbon built up on the inside of the valve.
3. Dump the carbon cleaner out into a container approved for solvents.
4. Finish cleaning the rest of the carbon out of the valve with a wire brush. Most of the carbon should come off rather easily at this point
5. Wipe the valve with a shop rag and allow the inside of the valve to air dry.
6. Reinstall and your done! Idling smoothly once again
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Scott B
10-24-2015 01:29 PM
