What is Servotronic. on the steering rack?
I found this...
Servotronic ZF Lenksysteme
http://www.zf-lenksysteme.com/filead...onic2_E_07.pdf
kool...
kool...
would you believe it is $20.00 cheaper than my 1992 MY non servotronic
I think either 1992.5 or 1993 started using them....
so that is what they cost cheaper than the one I should use...
it is just a electronicly controlled valve body that reduces the amount of power assist as your speed increases...
RagJag (11-30-2014)
well if you look through the above PDF you will find that the only thing the elec. control module does it send a control to the rack Valve body to vary the assist pressure.... even has graphs of speed vs newton/meters...
and
XJS SERIES - RACK DOCTOR - Quality Rack and Pinion Remanufacturing
if your read the above PDF the only wiring the electric control module need is the speed input to the speed-o-meter... and power of course
Woznaldo
09-26-2015 11:02 AM
