What Should the Cold Coolant Level Be?
Received 10,875 Likes
![Icon Emm](https://www.jaguarforums.com/forum/images/smilies/icon_emm.gif)
Hi, You should have a small pipe from the side of the header tank that disappears into the firewall corner....it goes into the LHside cavity behind the front wheel splash panel V12 (or on my UK 3.6 the RHside) Here is located the expansion tank at atmosphere which should be 1/2 full. This will be the source of that strange thump you here at times...thought you had bad suspension bushes ??? Anyway you will see the overflow just inboard, and probable no bottle fixing and a rust hole. Swear...one thing at a time.
The idea is that when the header is full and hot it pushes the extra into this tank...and the important thing is that now you have suction to draw it back when the coolant is cool if you don't open header cap and get air in the pipe.
The theory goes that you fill the header to the top, the car pushes out what it does not want via the expansion tank pipe. It cools down and you top it up cos their is some missing. So the expansion tank gets filled up and starts overflowing after a while.
Sound about right for your symptoms....now time to fix the expansion tank area.
Steve
xj-s 3.6 1988
Steve
xj-s 3.6 1988
Steve
xj-s 3.6 1988
Steve
xj-s 3.6 1988
i've actually been wondering about this because while my car has been leaking it has never once gotten "low" it just leaks down some..now i always refill it because obviously i don't want it overheating or something but i have never checked it and had it take very much fluid.
Hi, I have called the coolant recovery tank the expansion tank. This is the one in the rear of the front wheel arch. This is the one which should be about half full.
With the wheel arch cover in place...the only thing that you see is a 5mm steel pipe about 20cm tall and ending at the end of the inner side of the sill.
This is the overflow pipe from the recovery tank.
Nothing comes out of this pipe unless the recovery tank repeatedly/gradually gets topped-up from the header tank, but the header tank never sucks it back. Usually because you keep taking the cap off the header tank and topping off the system again.
The header tank under the hood is the one you normally fill to near the top.
OK OK...no offense intended you have to check, same here can't resist. But the best approach is after a couple of full heat and cold cycles, check the level in the header tank only. Do the same cycles again and I bet the level has not moved. If the level dropped too far the water level sensor would light the dash warning....does yours work??
Because of a C#*P design for the recovery tank, the coolant bypasses its overflow pipe and runs down the side of the tank.
Rust Rust Rust .... for the end of the sill and the lower wing.
You can usually tell which side of the car the recovery tank is on by the wing.
Hope that's not more confusing.
Have a read from Ed's site, he added a recovery tank plus it has all the nice pictures...thanks ED.
http://ecs.fullerton.edu/~sowell/jag...yReservoir.htm
Steve
XJ-S 3.6 1988
Steve
XJ-S 3.6 1988
Guy-Pierre Boucher
09-16-2015 05:55 PM
Johnken
09-15-2015 05:46 PM
