What are these bits of foam coming out of the air vents?
I have started to see small pieces of black foam poking out of my air vents, does anyone know what they are?
I have searched the service manuals and parts lists but cannot find reference to it. Is it from some kind of cabin air filter? Or possibly some kind of sound deadening? Is it important?
If anyone could provide a part number or description I'd be most grateful.
Thanks,
Allan
Thanks,
Allan
Received 10,905 Likes
I've had this happen on a variety of cars, inlcuding my older Jags.
The various flaps inside the climate control assembly have foam applied to help seal them and for quiet operation, and/or some of the ducting junctions use foam for sealing the gaps where they slide together. Over time the foam dries out, crumbles apart, and gets blow thru the vents.
Considering the amount of labor involved to disasemble the system just to replace some foam, most people decide it just isn't very important![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
AllanG (06-17-2013)
To add to what doug stated, The only issue this causes is that you get blow by. So if you want it to come out of the bottom you might have some leak through to the top vents. I have noticed this on many of my vehicles and starts happening sooner on the cars that I don't leave in the garage. So I assume the heat just cooks the foam till it is fragile and the fans blow it around the vent system.
BrentGardner
28
04-26-2024 03:08 AM
Series1fan
09-05-2015 08:02 AM
SingBlueSilver
08-27-2015 02:20 PM
