What is the Thickness of XJS Front Shock Absorber Bushes?
orangeblossom (07-17-2017)
orangeblossom (07-18-2017)
Another option is to go to the bush used with the bilsteins if you are looking for less compliance.
orangeblossom (07-19-2017)
OB, if you are not using the OEM foam type bush the thickness won't be entirely relevant. That foam compresses down a lot more than a poly replacement will so you may have to resort to a bit of trial and error.
Cheers!
I've just made a Set from a very hard piece of Rubber, which was 19mm Thick so I cut them down to 16mm with a Hack Saw.
Making them was easy but getting the lock nuts off was a PIA!
One of them took 4 Hours to undo and the other one took 8 Hours!
The most difficult Nut I have ever had to get off in my life, even when I hacksawed it through on three sides and in the end I had to resort to a FBH and Chisel!
I just don't know where the time went?
One of the Joys of owning an XJS
I'm planning to do a full write up of removal and refitting on my 'Cherry Blossom' Restoration Thread.
