what timing mark to use
Still trying to get things right on my 1984 XJS, but I may be using the wrong timing mark when setting the dizzy back in. The manuals state to go to compression stroke (did that), then set to 10 degrees BTDC, (did that). started up fine but runs like crap.
So, pulled 4 plugs and can see the timing is not setting up right from reading the plugs. Did try to adjust the dizzy. So, since mine is a 84 with the 5.3 HE, and the sticker on the hood calls for 18 degrees BTDC, do I set the timing mark at 10 or 18 before putting the dizzy back in?
![Icon Flamethrow](https://www.jaguarforums.com/forum/images/smilies/icon_flamethrow.gif)
![Icon Viking](https://www.jaguarforums.com/forum/images/smilies/icon_viking.gif)
Grant will chime in and tell you 10 is what you want so start there and drive time it to just below detonation.
But I'm curious just what you mean by "reading the plugs". Also, what are you aligning the dizzy with while you have the engine rotated to 10 BTDC?
Spec for your car is 18 BTDC @ 3000 rpm with vacuum disconnected and plugged so that will be all centrifugal advance and static timing. I assume the centrifugal contributes about 8@3000 but I don't have the service manual. Page 5-1 has a table of the centrifugal curve I believe.
If you're at 10 BTDC static and running but very poorly then I'd check to confirm your vacuum advance is working and that your plugs are all gapped correctly.
Grant Francis (09-03-2016)
Here ya go, simple.
If something is lost in the translation, please ask, and I will sort it.
HE Tune up.doc
Refitting the V12 distributor.doc
Trimming the timing on a running V12.doc
Some of the scribe you will not need, and I feel you are good enough to by-pass that.
HE Tune up.doc
JigJag (09-04-2016)
Here ya go, simple.
Attachment 135487
Attachment 135488
Attachment 135489
Attachment 135487
Attachment 135488
Attachment 135489
Have the service manual and workshop manual, manual states when putting distributor back in and engine has been turned, turn engine so #1 is on compression done that) , then complete rotation to 10 degree setting which would be static from how I read it (did that). Then make sure rotor is on #1 (did that), while holding the rotor to prevent rotation, place dizzy in lining up the #1 mark on pickup module with the rib on the rear to the cover plate.
But must be missing something, because I can tell from the plugs, they are black and sooty, which means the timing is off even though I tried to make adjustment screw on the dizzy.
Last edited by daverb; 09-03-2016 at 11:49 PM. Reason: finish reply, internet went out
I have now gone to areas of a laptop that I NEVER knew existed, and scary is an understatement. Almost had me returning to the JD.
Here ya go in PDF format, IF I have done it right, haha.
HE Tune up.pdf
Refitting the V12 distributor.pdf
Trimming the timing on a running V12.pdf
Since you are such a nice guy, ENJOY.
OH BOY.
Attachment 135549
Attachment 135550
Attachment 135551
Attachment 135549
Attachment 135550
Attachment 135551
![Icon Starwars](https://www.jaguarforums.com/forum/images/smilies/icon_starwars.gif)
Thanks Grant, you sure have been a lot of help for this old man
Grant Francis (09-05-2016)
Greg in France (09-05-2016)
The following 2 users liked this post by Steve M:
Grant Francis (09-05-2016),
Grant Francis (09-06-2016)
Grant and some of the other long time experience ones know all I have been doing to mine for the past 2 or so years, have photos in my profile area, must say it has kept me busy and with my physical limitations I get done at a slow pace but get it done
FS[UnitedKingdom]: Set of 4 19" Propeller Alloy Wheels from Jaguar F-Type
PaulParanoia
04-12-2016 05:42 AM
FS[Central US]: Compression Nut and Blanking Plug XK8
BStreet
03-24-2016 12:00 PM
