What triggers radio antenna extension?
Does the ant go all the way down to almost flush of trunk or is there a small section about 6 inches that stays up? Just asking because that's how mine is lol. And its loud lol.
Yip, I had that problem too. It’s because the nylon teeth are worn on the aerial. It’s a reel that winds up and down. You can replace this on its one. The mech comes out with a couple of fixing at bottom. Be careful to reposition the rubber mounting bushes inside if you replace it. That is likely where your issue is!
https://www.sngbarratt.com/uk/#!/Eng...4-53783e8a2b82
Lucielle (10-25-2021)
Hi V1rok
Its the 'Blue' Wire that Triggers the Aerial to go up and down
Here is a complete installation guide to fitting an Aftermarket Stereo in an XJS including loads of Step by Step Photos
How to fit an Aftermarket Stereo in an XJS Full Step by Step Guide including Photos
How to fit an Aftermarket Stereo in an XJS (version 2) Step ny Step Guide including Photos
The following 3 users liked this post by orangeblossom:
Good point. When I did mine I wound it in enough sufficiently only to reassemble and then reattached the wiring and let it wind itself back in. Seemed to work fine and has worked since , I couldn’t find a documented procedure...
Where exactly is the antenna relay located in the trunk? You said it should be green. I checked in the trunk and I see two on the right side: black and red (fuel pump and main relays). I did not see any green ones.
Antenna relay is located next to aerial motor assy. Big green relay, at least on my -89 coupe. My aerial is not having any mechanical switches, i would say that small circuitboard inside motor assy senses when motor stalls and then stops current.
Just fixed my aerial and only timing was just to extend it and make sure that nylon cord is still on the reel. Aerial outer shell, metal one, could be just stuck together if someone pulled it by hand. Should be possible to free this just by tapping aerial from the top. (maybe advisable to remove it and do separately)
My problem was continuous running, which propably was due to corrosion on that small circuitboard. Caused by leaky aerial grommet on wing, this little ******* let all the water directly on motor assy if broken.
Hi V1rok
The Big Green Relay is located in the same place as the Aerial behind a piece of Trim
This Link has a Photo: which will show you its exact location
Which also includes
(1) Fitting a New Aerial Grommet on the rear Fender/Wing
(2) Dashboard Light Bulb Upgrade using Normal 5 watt type Bulbs if you don't want to fit Led's (which I don't)
(3) Simple Fix when all the Dashboard Lights go out for no good reason due to faulty Dimmer/Rheostat
Location of Aerial Relay and Bulbs For Dashboard Light Bulb Upgrade
Which also includes
v1rok (10-27-2019)
I have just fitted a new aerial for a mate. The easiest thing is to buy a new aerial from Amazon, and use the original body fitting, so the top is flush with the body as before. New aerials have the activation chip built in, so you can do away with the green relay in the boot, and just hook the new aerial's wires up to the signal, 12v feed, and earth.
This one is ‘85, US version.
I finally figured out where the motor and the relay are located on mine. It is kind of in a crevice down below, right next to the rear wheel well. I had to remove the trim around it just to see it. Also saw the green relay behind the motor.
Kind of difficult to access...
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
orangeblossom (10-27-2019)
