What is this Wire for?
Old 09-19-2017, 03:38 PM
orangeblossom's Avatar
Received 3,773 Likes on 2,612 Posts
Default What is this Wire for?
What is this White Wire with the Black Connector?
Old 09-19-2017, 04:17 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
That is the dreaded white wire.
On Marelli cars (early ones at least) pin 24 of the Marelli goes into the engine bay and connects to where the Lucas ignition amp used to be. Obviously Jaguar did not change the main harness through the car.
orangeblossom (09-19-2017)
Old 09-19-2017, 04:41 PM
Hi Warrjon
Cheers!
Obviously essential that it doesn't become disconnected.
Old 09-19-2017, 07:29 PM
baxtor's Avatar
Received 1,154 Likes on 746 Posts
Originally Posted by orangeblossom
Hi Warrjon
Cheers!
About as important as oxygen is to you OB.
The following 2 users liked this post by baxtor:
orangeblossom (09-20-2017), warrjon (09-20-2017)
Old 09-20-2017, 04:50 AM
warrjon's Avatar
Hi Warrjon
Cheers!
If you disconnect this wire the ECU will not fire the injectors.
