whats causing my hard brake petal
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
On my 1988 Jaguar xjs my brake petal feels very hard, to stop I really have to give it a lot of pressure for a quick stop. The petal doesn't sink but it doesn't really move much pressure till at the end of the petal. I replaced all pads, rotors, and fluid. is it the booster or can it be cause by another series of problems.
Received 10,872 Likes
Rusty/stuck caliper pistons, rusty/stuck master cylinder piston, collapsed brake hoses. This can be from age and use....or from long periods of non-use.
My experience is that a failed booster doesn't give a hard pedal in the sense of very little pedal travel. You'll have to press the pedal harder, of course, but it'll have normal movement/travel
Also, some brake pads just require a lot of effort. I had a set once where I thought I was gonna bend the pedal before getting any "bite" from the brakes. I switched to a softer composition pad. And....some pads have a specific bedding-in procedure which, if not done, will result in low stopping power. The typical bedding-in is several very hard stops from about 40 mph with maybe 30 seconds in between. Don't lock the wheels and don't come to a full stop. But, some parts have a different procedure.
The following 4 users liked this post by Doug:
75Gremlin
10-29-2017 03:30 AM
venom_99
67
11-23-2012 12:09 PM
stdjrm17
04-18-2008 10:04 AM
