What's missing
Old 06-01-2017, 11:59 AM
Carl Spandau's Avatar
Default What's missing
I need help identifying what's missing from the fire wall of my car. I have a large opening on the passenger side that lets a lot of hot air in. I plan on just making a plate to cover it but wasn't sure if it was part of the AC
1985 jaguar Xjs
Old 06-01-2017, 12:19 PM
Greg in France's Avatar
Received 9,251 Likes on 5,433 Posts
The two sides of the car are symmetrical. If yours was RHD the pedal box would bolt into that hole. As yours is a mid 1980s or earlier car, that space has the vacuum reservoir for the aircon it, covered by a plate, with the screen washer reservoir on top.
Old 06-01-2017, 02:18 PM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Something looks wrong. That isn't a V12 nor an AJ6 in there... So I assume a V8? Then see if you can get the blanking plate
Old 06-02-2017, 10:02 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Daim:
Good eye. Tis a Chevy V8. The "ram horn" exhaust manifold is the tip off. Plus the valve cover. GM, definitely is in there.
Blank it off seems to be the fix!!!
Carl
