Wheel lug nuts for spoke rims
I'm doing some guessing here since I have an 87. My wheel studs are all the same. They are 1/2" X 20 thread. If you have Dayton Wire Wheels you might check these out to see if they are the ones you need.
Dayton Wire Wheels 3-0150 - Dayton Wire Wheels Lug Nuts - Overview - SummitRacing.com
Do you know the length of the ones you have????
I think you have me on the right trail. Many Many thanks.
len in michigan
I don't have wire wheels but I know that the Jaguar XJS has 1/2 X 20 studs. You can identify your lug nut from one of the old ones to see if it is a conical seat, standard or bulge. For my alloy wheels it requires the 60 degree conical seat, bulge type. Mine are open ended. For your wires, you will need to determine if the seat is a standard conical or bulge conical. The length is determined by what is required to cover the stud since yours are closed ended. Once you determine the seat and the length you need, any style can be used from any manufacturer. Here is a little more reference material that might help make this all clearer. Compare your old one to the charts to determine the seat.
http://www.mcgard.com/files/pdf/lugnutref2009.pdf
Lug Nuts - Cone Seat - McGard: Innovative Security Products
hunter34
19
09-14-2022 11:09 PM
lickahotskillet
10-18-2015 09:51 AM
