Wheeler Dealer Vender for British Car Wiring Harness
Old 12-22-2022, 08:00 AM
BSM's Avatar
BSM
BSM is offline
Default Using multiple fuses
One of the signature limitations of the Mark 2 wiring is that there are only two fuses to protect the whole system. Not only is this a very poor protection scheme but it also makes trouble shooting very hard indeed,
I fitted a standard new wiring harness to my car and added a multiple fuse block. This is very easy since the power wires all converge at the original fuse holder and it is a simple matter to spread them out individually so that each one has its own fuse.
Attached is a copy of my supplemental manual that shows some of the details. Although I have done many other modifications to the wiring at least you can see the multiple fuse approach I took.
Also attached is the maker data sheet for the fuse holder.
File Type: pdf
File Type: pdf
Brewtech (12-29-2022)
Old 12-22-2022, 11:47 PM
brinny's Avatar
Check-out Mobeck Tekniske on you tube. He does harnesses I believe.
71JagXKE
E type ( XK-E )
10-23-2019 08:41 AM
Gladiator
Canada
01-28-2017 02:10 AM
ryan volland
11-25-2015 09:25 AM
MK2
03-31-2015 11:30 AM
Dan Bennett
03-27-2015 05:30 PM
Quick Reply: Wheeler Dealer Vender for British Car Wiring Harness
