Where to get reground cams for the v12?
The PO of my donor had Crane do a special grind on their cams in my motor. I'm not sure Crane offers XJS cams anymore. I don't see them listed on their website, but, you may want to contact them to see if they have any NOS sitting in the warehouse, and if they would do a grind for you. Isky also used to offer cams for the XJS.
Do you have a specific lobe profile in mind?
Another source is www.V12sales.com
Received 1,236 Likes
cal, reground factory cams really are not the best engineered, for performance, regrinding reduces base circle diameter, and that increases stress at the tappet and valve. also the best of Jag V12 guys used a large diameter base circle, along with larger diameter tappets& blocks
you seem like your building a serious engine, myself i would try to find some unfinished core blanks, and have them finish ground to a usefull specification!
a set of hi-performance 5.3 cams may not give the performance you expect!
just maybe a set of 6.0L would be closer to your requirement, they are designed for a 6l engine by Ford engineers.
FS[Western US]: XJS V12 Convertible
marklcap
09-29-2015 12:41 PM
