where is my transmission filler plug? and where is the code reader plug?
i'm the process of changing my 94 4L 6cyl.... I see where the drain plug is, but I don't know where to fill it from... any ideas?
Also, I went to autozone yesterday to get some codes read, I think my plug is in the trunk ( next to the security pc?) and it is rounded (there is nothing under the steering wheel and foot well ... any way.. they guy at autozone told me that they can't ready codes in 95 or older cars.
any ideas?
any ideas?
Received 10,877 Likes
Automatic trans, I presume? I suspect you add fluid thru the dipstick tube as with most any other auto transmission.
Not sure about reading the codes on a '94. Someone will chime in on that. On 95/96 and newer cars it's easy because the mandated OBDII systems are pretty universal as far as code readers goes.
I'll give it a try.
oh... what about the filler for the rear differential?
You'll need to buy a special funnel that can fit into the small dipstick tube.
I'm pretty sure there's no way to read codes in your '94. The '95s have a half-baked OBD terminal. The '96 were the first XJS models to have a real OBDII plug.
I would assume any codes stored would have to be read by special equipment specific to Jaguar.
some time ago I was trying to program the a remote key I had bought on ebay and I performed the wrong sequence... it did give some codes like FFXX....
how to perform that same sequence now?
@rama
Good to see you are still persevering with your XJS :-)
I am assuming your Check Engine Light on the instrument cluster is on ?
If so, get in and turn the key to ignition on but do not start the car. Watch the trip computer screen...... you should see FF xx appear, where xx is the fault code number. I think if you have more than 1 code, it only shows the most serious one. (or it may cycle through all of the codes, I've luckily never had multiple codes so I'm not sure exactly)
I have a printed list of the FF fault codes in the car, but I'm not at home this week. Anyway, you can google "XJS FF codes" and you will find plenty of online resources.
To clear the codes, disconnect the battery for 60 seconds, then reconnect. Obviously if you have not dealt with the problem, the code(s) will come back once you start and drive the car.
Post back if you can get the codes out of it
where is the coolant temp sensor?
Also, I flushed the transmission fluid yesterday but was not able to undo the filler pipe that goes into the pan.... that thing is either really rusted or really tight... not even liquid wrench or pb-blastt worked.... so I just refilled it without changing the filter.... sucks!
aholbro1
08-05-2021 05:02 AM
