Why does it not start after ?
I had my 87 XJS V12 starting and running all week from Monday to Friday. Come today Saturday and engine won't start at all. Added fuel even though it was half full. Cranks strong but won"t start at all. Don't really know what to look for. Any input from you guys is most appreciated.
If Gareth's point checks out OK, I suggest:
Ignition on, floor the throttle pedal while someone listens to the injectors, they should click once as you floor the throttle (a Grant Francis diagnostic tip)
Check for spark. If no spark:
Check that there is 12v to the coil, ignition on.
Check that all the leads to the coil are intact, the copper can break inside the connector insulation
Clean the resistor pack plug connector
Check the plug, lead and mid-point connector on the twin wires from the coil bottom to the Lucas amplifier
Check the (dreaded) white wire from the amplifier that goes rearward into the engine loom to ensure connector OK and wire intact and not shorting out to the shielding
The following 3 users liked this post by Greg in France:
Grant Francis (04-22-2024)
