Why is there a hole in the floor?
My '87 is the same only the bolt is in the hole, screwed in from the bottom. If you look underneath you will see a horizonal bar a couple inches wide. Maybe some kind of body rigidity enhancement..
I have an '88 I am parting out. I will see if I can get the bolt out for you if you want it.
Grant Francis (09-08-2020)
Greg in France (09-08-2020)
