Will not start - Help - clicking sound - 1994 XJS
Hello, I am a disabled senior in Napa, CA and my daily driver vehicle will not start. Any assistance or help would be appreciated.
1994 XJS 2+2 6 Cylinder, auto with 210,000 miles... Had AAA come out and look at the car, checked battery and alternator and those checked out. Vehicle turned on when jumped, but was dead the next day. It appears to be an electrical drain or a relay problem? Although I am not sure.
Symptoms.
-Clicking Sound near lower passenger door or engine. Hard to tell.
-when I open the rear hood the clicking sound stops and starts again upon closing the hood. odd.
Symptoms that may or may not be related.
-For past few weeks, when car ran, windshield wipers would not shut off - need to try different settings to shut them off. stay off for 20 min then restart.
-2 weeks ago the car alarm went off at 3am for no reason.
Help. Thank you.
Symptoms.
Help. Thank you.
Ronald. The battery was purchased from AAA last March. So should be good and AAA tech tested battery and he said it was good. Something is draining the battery in the vehicle.
You may well have something creating a parasitic drain on the battery.
First thing is to measure the quiescent current at the battery. Remove the negative cable from the battery and connect a multimeter set to amps between the negative post and the disconnected cable.
Ideally you should see less than 40 milliamperes. If you have a lot more, then go to each fuse box in turn and remove the fuses one at a time while viewing the meter. When the meter reading drops you will have found the circuit that is causing the problem. Just check the manual and see what components are using that fuse and trace those circuits.
Yep, that can happen. Easy to check though. I put my camera phone in movie record mode and stick it in the boot and close the lid. Open the lid and and replay the movie. Simples
Because the law of sod will apply! Shutting the lid may not press the switch enough to break the contacts.
ahh, i guess that makes sense. If you don't have access to something like that and haven't changed to LEDs like me you could also just check to see if the lamp covers are hot immediately after opening the boot lid. If they are, then the lights were not going off
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
