NOPE video wont go ,sorry wanted to show new LED BAR lights!
second time car coming up behind and slammed on brakes , said NO directionals , well LUCAS lights are from the dark ages, barely glow in bright sunlight!
already tried LED bulb not much better , but the new BAR LEDs are fantastic!
if you drive in traffic with original factory lights you may need something more than a joke!
ron
walmart , dont have any part numbers tho,, $18. dollars for the pair with mounting brackets, and wire connectors!
best part is they hook directly to the factory wiring, NO special resistors or anything!. something called a COB inside?
i will get better pix! these LED bulbs mounted in factory place are TOTALLY Useless.
ron
well me being old fashioned always just did things that really work for my needs, like no numbers or directions!
seen these at wally world , so decided to make them work in place of factory stuff
24 LED;s in each BAR! hope this helps with old lighting problems!
ron
someone mentions because fronts are incandescent factory wiring will work, and it does!
but they are much brighter than originals,, cost at wally world, $23. for the pair of fronts! this is without lite ON , much brighter with power on , i may try to get a shot when blinking, park is not as good!
much more important for rear lites ,,after two almost rear collisions, in bright daytime sunlite!
