window motor replacement
Greg in France (10-28-2016)
Since you probably have the door panel off, best way to check if the motor is working or not is to unhook the two leads from the motor (black and red) and hook them up to a 12V source and see if they go up and down. If so, the motor is good. BTW, reverse the leads for up and down. If the motor makes noise but no movement, perhaps the glass is stuck in the window rails that may need adjusting. If no noise from the motor, probably bad.
good luck
Ken in WV
good luck
Ken in WV
Greg in France (10-29-2016)
