Window Switch Problem - Oxidizing Contacts?
My passenger's side switch keeps failing. Everytime I open it up, I notice black "oxidized" areas on the metal contacts. I keep cleaning it up, but it seems to come back within a few days.
I've attached a photo of what it looks like.
Any suggestions on a fix?
I think the switches are the same as my old 1985 VW Jetta.
The Jetta switches started getting 'balky' and intermittent so I pulled one out to look at it.
The plug looked familiar so I looked in my tool box and found some old Jaguar XJ-S switches and they fit (and worked).
You might find some old 1985-1989 era Jetta switches in a salvage yard for parts???
They are probably cheaper and easier to find used (or new??) than a Jaguar switch.
The rocker part is larger on the VW switches but they might fit.
The smaller rocker worked in the VW mounting hole.
bob gauff
bob gauff
Beware of the $20 switches. If the switch housing has plastic tabs, then they will not fit into the bezel opening. I bought one a while back.
I ended up pulling that part out and doing some open heart surgery on the OEM part. Its now a Frankenstein mix of the two, but hopefully should work, trouble free, for years.
In the meantime, I will try to electroplate the OEM parts and see what happens. At worst, I throw it in the trash...
I'll let you all know what happens.
