Windshield washers
What, do you think, is the one way valve for on the w.w.. Is it to stop the water being sucked out when driving.The reason I ask is that the washers don't have "super car" power unless I bypass the valve. Will it let the water leak out when driving if I leave it out?. I can't test it myself as I have
removed the container at the moment for re-plating the blanking plates and reservoir retainers
I recently replaced both washer motors and wired them together so one for each of the jets, I fitted power wash years ago with the reservoir under the r.h.f splash panel and relocated the vacuum reservoir to the l.h side, straight fit to existing brackets, so I could try and improve the w.w. power but it disappointingly made no to difference to performance, The power wash on the headlight work, with extended wiring, as the old ones did, but I have never had cause to work them as I don't drive at night anymore.
Greg in France (09-08-2019)
I do not believe they are on an XJS, as on my car the tubes are not (OEM) over the engine. Heated washers were electrically heated items, like heated mirrors and rear screen.
xjrjag
07-13-2017 02:23 AM
wackymatt
01-26-2015 07:20 AM
