Wiper issue, how to proceed ?
Hello everybody,
I'm facing a wiper issue on the 1983 XJS for a long time, it started with rain on the wiper engine not covered anymore by the plastic protection. Thank you to the garage, my car was outside.
Now I've replaced the engine but this is still not running. What can I check ? Fuse box ?
Thank you.
Ya
Thank you.
Ya
Last edited by GGG; 03-26-2020 at 04:13 AM. Reason: Add Model and Year from post #3
Hello everybody,
I'm facing a wiper issue for a long time, it started with rain on the wiper engine not covered anymore by the plastic protection. Thank you to the garage, my car was outside.
Thank you.
Ya
Thank you.
Ya
- fuse, and test for current BOTH sides of the fuse, they often look entire but have failed at the connection internally.
- If OK, then test the wiper stalk in ALL its settings: normal, high speed, flickwipe, intermittent. This is to eliminate (to a degree) a possible stalk-switch problem on an individual mode. If nothing:
- remove the wiper unit an unplug it, from the black socket on the bulkhead, then turn on the wipers to normal speed and using a test light see if there is current to the socket (there are several connectors in the socket but one will be live, if not two). Switch off and test that this connector goes dead.
- redo this test with someone holding the stalk on the flickwipe setting and check for current again.
GGG (03-26-2020)
nebelfuerst
02-06-2013 06:10 AM
