Wiper linkages
Old 12-31-2019 | 08:15 AM
Luigi1889's Avatar
Default Wiper linkages
I have an 88 xjs RHD with stuck wipers. The motor is fine but the linkages appear shot. Can these be replaced and how?
thanks
Old 12-31-2019 | 11:39 AM
JayJagJay's Avatar
thanks
Do you have a photo or can you get a little clearer in what you are dealing with? Stuck?
From memory,,, the entire assembly can be lifted out with the removal of a couple of bolts and some fiddling. Be careful with fingers and on/off... It's often underestimated,,, but that damn wiper motor, its hinges, arms and bars will do a NUMBER on unsuspecting fingers. Very careful...
Old 12-31-2019 | 11:54 AM
Luigi1889's Avatar
The bushes seemed to have perished are they replaceable?
Old 12-31-2019 | 12:15 PM
JayJagJay's Avatar
Right! Thanks. I hate to post a link rather than answer... But I would do this...
https://rover.ebay.com/rover/0/0/0?m...2F402008242923
Old 12-31-2019 | 12:17 PM
JayJagJay's Avatar
Or,,,, really give a go at freeing it up... Might take some work, but worth it... They are pretty tough
Timeisrelative (01-01-2020)
Luigi1889's Avatar
Thanks does that mean the bushes cant be replaced?
Old 12-31-2019 | 01:54 PM
Bez74's Avatar
Hello David
I think first thing first is to confirm what is tight. I would do as JJJ advised (also carefully) and confirm if the motor is tight or if the linkages are tight.
If the linkages are tight - I would place Singer sewing machine oil at all the pivot points and see if you can free them up over time.
Sewing machine oil is brilliant - does not harm the rubber at all and has freed up a lot of things for me in the past.
Just for knowledge - the difference between earlier models compared to the 89 series below
Steve
Old 12-31-2019 | 02:06 PM
JayJagJay's Avatar
I'm unsure... I would try and write directly to a few of the major suppliers... It's a tough search. I did a search and came up with a few hits BUT,,, with the trouble of finding the parts, separating all of the old hinge points, the cost of the, what, 5, 6, 7 bushings and HOPING for a flawless reassembly (really,,, it's a pretty intricate set of connections that have to work well thru a million cycles) I would rather just work with what I had or just get a "new" set up... A used one could most likely be found pretty easy...
​​​​​​Is every point really seized and/or locked up. Or just a few?
Old 01-01-2020 | 11:50 AM
Luigi1889's Avatar
Just a few. I think I will try the oil first. Thanks for all your input. Happy new Year.
Old 01-01-2020 | 01:19 PM
mghirsch's Avatar
You say the motor is fine. How did you check it?
On a couple of my Jags, moisture got into the motor and caused the magnets to rust, breaking the bond with the housing. I took the magnets out (marking their orientation), cleaned off the rust, and re-glued them. If you do it, make sure that there is sufficient clearance between the magnets and the armature.
Old 01-04-2020 | 10:46 AM
jag_man653's Avatar
I retrofitted a wiper assembly like yours to my '76 coupe. As part of the project, I disassembled the assembly, sourced the parts, and rebuilt it. My write-up on the project is at my website.
http://www.efsowell.us
Old 01-05-2020 | 09:40 AM
Luigi1889's Avatar
Ed,
Thanks for your help, I love your website - I think I may have a few other project ideas after I have solved this.
Old 01-05-2020 | 02:10 PM
jag_man653's Avatar
David, if you decide to remove the wiper arm posts you will likely find the nylon washers shot. Like other parts of the assembly, these were never intended to be replaced so never available parts. I had some machined from nylon stock and have many extras. Let me know if you need them.
Good luck.
d
Old 01-05-2020 | 02:16 PM
jag_man653's Avatar
Also, I have a complete face lift ('92 on) wiper assembly. I mistakenly bought it to retrofit to my '76, but it doesn't fit the earlier cowl cavity. The motor might fit though. I recently listed the assembly in the XJS Parts For Sale forum for essentially free ($5 + shipping) after having it on eBay for months without a bid.
Old 01-05-2020 | 03:59 PM
Timeisrelative's Avatar
Man! I wish it would have been available when I bought mine! Shucks!
Per Greibe Soerensen
01-30-2019 05:14 PM
NathanDD6
05-25-2016 01:40 PM
chirt
04-22-2014 10:15 AM
Lanny Edgeman
01-08-2012 12:58 PM
CatLovr
12-03-2009 08:54 AM
Quick Reply: Wiper linkages
