Wiper park position
Wiper park position
My passenger side wiper touches the windscreen rubber seal.
I have just renewed the wipers, and the old wiper was doing it as well, but much worse. I turned the new wiper the other way around to make it as short as possible, but it still touches the rubber.
PO had placed a large piece of black tape to protect the rubber and chrome. I removed it as I thought I had solved it by turning the wiper around...
Should the wiper park higher on the screen ?
Wipers are 15" as recommended by all the.sites I've found...
orangeblossom (05-22-2016)
Hi Leo,
My '90, 3.6 also has 15 inch wipers but they park higher on the screen than yours so that the outside wiper is about 1 cm from the screen edge at each end. It was like it when I bought the car and as I thought it looked a little untidy I was thinking of investigating if I could make them park lower but now I can see I might have the same issue as you so will probably leave them. Personal preference I guess.
Cheers,
Lee
Cheers,
Lee
When I first got it, they were parked way too high and blocked my view:
They're pretty easy to adjust, just pop the cover, 13mm bolt, set new position:
Now they fit great (more hidden):
Yours are opposite of mine. Strange that they are too longer on the outer edge. Since it's the passenger side, I'd use a 14".
Padre
Hi all,
My wipers look exactly like Padre's before he adjusted them to park lower down the screen.
However, I hadn't realised that on his side of the big pond the wipers park on the same side of the screen as they do in the UK. So I can appreciate this would not be good for the driver's visibility.
Fortunately, in the UK, this only effects my wife's view of life in the fast lane so assuming she does not discover the forum I will leave the wipers where they are.
Cheers,
LeeP
Cheers,
LeeP
Mine park on the right also. They used to sit high until I dismantled the motor and cleaned and lubed it. It's like you have a left drive car with right drive wipers. They where probable out of the left drive sets and installed what they had. Must of been Friday afternoon. Lol
Of replaced by someone who didn't know better
I've just checked my Wipers and they are 15in but don't overhang at all on the Passenger side.
Could they be a different make or maybe Aftermarket or something?
It is perfectly possible, on the UK driver's side parking wipers, to shorten the length, either by buying a shorter blade or a shorter arm. The problem is you lose swept area at the top of the screen. Mine park on the driver's side and one easy mod that I have done is to bend the arm downwards to make it lie flatter when parked - but the blade still overlaps and rests on the rubber.
Greg
orangeblossom (05-23-2016)
Assuming the blades and the arms are the standard length the answer is no. Your park better because they park on the UK passenger side, rather than the UK driver's side. There appears to be absolutely mo rhyme or reason why some cars had them parking one side, and some the other. There is, apparently, no model, date, or country conformity!
Greg
Greg
That's a crazy situation
I wonder what they were thinking (or maybe not thinking in this case) to do something like that.
the way the blades park is due to which motor they used, some are Electrolux and some are Lucas, there is a setup guide in the ROM for the XJS and describes how and where the blades sit ,
but basically , the one sits level with the lower windscreen rubber , and is parallel to it
the other one sits right on the edge of the windscreen rubber( not over it ) to the side, any overhang for the standard 15" blade must be corrected to achieve this position ( as in the grey car pic above )
BB
BB
Depending on VIN a different supplier was chosen. My 89 parks the wipers on the left. A friends 92 on the right. And I've seen younger and older ones with different parking sides. So I guess it is random. I remember reading in my Enthusiasts Guide that it said, that a different supplier was chosen.
If they were redesigning the XJS
I would have to mention the Wipers.
BB
BB
Well that's cleared that up.
So Thanks
being a 94 car it might be even more difficult, but basically you have to swap out the complete wiper box and also the steering column wiper function stalk as the stalk, wiring and motor are all matched for each brand of wiper motor, ( Electrolux or Lucas )
if the stalk isn't changed , some funtions on the alternative motor doesn't work, ( like single pulse wipe, or timer wipe etc )
BB
