wire wheel question
Consider wire wheels very carefully.... They are super heavy and make an XJS ride very poorly. They're difficult to clean also tubes are not commonly available anymore. So in a pinch you might be stuck. I understand they do have a classic look though that appeals to many.
The following 2 users liked this post by fishbait1:
Greg in France (12-15-2019),
Mac Allan (12-15-2019)
yes, the adapters bolt to the hub ( standard lug nuts). the wheel slips over the adapter and then the spinner tightens the wheel onto the adapter. tighten with a lead hammer and ready to go. the adapters remain in place when you remove the wheel for cleaning or whatever so you should not have to remove them. the time to pull a wheel or put one one is about the same as with using lugnuts and impact wrench, maybe quicker. the biggest issue was getting them balanced. nobody wants to do it. i tried 3 of the local wheel shops with no luck. finally found out a guy in our car club had a wheel balancer and mounting equipment. wire wheels are the wheels that belong on these cars IMO.
#28
I got 7x16 wheels with a 33 offset. that is the size wheels that were on the car. I don't know if the wires required a specific offset I just told Dayton he size wheels that were on the car. when you order the wheels you must get the adapter kit for the wheel ( see generic picture). the adapters are universal fit . the lug nuts are a standard 1/2x20, same lug nuts that are on my 1960 Impala. the bad news-- a little over $3100 for everything !
I sent Dayton the inserts for thew spinners and the machined the spinner to attach the growler inserts.
#30
