wires
The sender has three wires coming from it. One is an earth (black wire connected to the tab on the metal body of the sender unit). The other two go to the gauge (one is the low fuel warning light, the other works the gauge). In the boot RH corner somewhere will be the loom connectors for the two. Also check the earth wire goes to a good clean earth (normally found on the boot RHS exhaust tunnel top).
Greg
Greg
My 89 too. I think the looms evolved as new components came into being/changed in some way but because a lot of these changes happened piecemeal rather than at a certain cut off point the looms sometimes needed to suit both setups.
