Wires in the V
Old 05-30-2015, 11:39 PM
darrhel's Avatar
Default Wires in the V
Greetings
While cleaning out the V I found two wires running along the bottom right hand side, both covered in oil and crap as you would expect.
Both running the length of the V and coming out under the AC.
The green wire with the blue stripe went off to the right to the temp sender at the front in of “A” bank. ( this one has now been rerouted out of the V.
The other one, a lighter green with a brown / slate stripe went off to the left to the front of “B” bank and was not connected but had a straight connector spade on it, the first time I had noticed this particular wire. The engine temp and air intake sender on the left side are intact with no missing or broken connectors. Can not see where this would connect to but will keep looking….!
Any comments on what this wire is for or checks I should do would be much appreciated.
Darren
Old 05-31-2015, 12:56 AM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
I think that wire is for your A/C compressor.
darrhel (06-01-2015)
Old 05-31-2015, 08:14 AM
Katoh's Avatar
Had the same problem, will just simply refer you to this thread.
https://www.jaguarforums.com/forum/x...hey-go-114202/
Old 06-01-2015, 12:21 AM
darrhel's Avatar
Default Thanks Baxtor and Kato
Yes it was the AC wire as you suggested, all fixed and sorted and re run out of the V
much appreciated
Darren
jagent
06-05-2022 02:18 PM
Poet
06-07-2019 07:54 PM
Rocky15
09-28-2015 04:59 PM
FabCat
09-26-2015 12:16 PM
driver safz
09-26-2015 06:01 AM
Quick Reply: Wires in the V
