Wiring/Electrical Problem help please
Old 06-13-2012, 07:51 PM
Greg Edge's Avatar
Originally Posted by JagVilly
How can i tell if the relay is dead by looking at it?
You can't. You have to test it.
Old 06-14-2012, 05:46 AM
tcharron's Avatar
The easiest way to test it is to swap it with another relay. On my 92xjs, the horn relay is the same type of relay and is located in a small bank under the hood over the passenger side front wheel. I think that there was one or two screws holding a small cover pver this bank of relays which made it very easy to access.
Old 06-04-2015, 07:33 PM
Pudelspringer's Avatar
In my RHD 1990 XJ-S, the fuse cover does not list a fuse for the brakes. I have a third light. I was changing the bulbs to LEDs.
Park lights still work great, but no brake lights from any of the three fittings. I have replaced LEDs back to the bulbs.
Any idea where the fuse is? It is not listed in the manual either?
Old 06-05-2015, 11:45 AM
Greg in France's Avatar
Received 9,284 Likes on 5,453 Posts
It is fuse no. 5 in the main fuse box, which controls direction indicators, stop lamps, and kick down switch, according to my XJS HE Jaguar OEM book. 15 amp. If your indicators are out too, fuse looks likely.
Greg
Clamdigger
09-12-2015 03:43 PM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: Wiring/Electrical Problem help please
