wiring issue.. many.. seventh
Well the white spade connector is probably coil + to the main or 2ndary coil (will be hot with key-on). The White/Blue wire is likely the tacho connection from the amp as seen in reply #3 to your other post: https://www.jaguarforums.com/forum/x...0/#post2635465
The white bullet connector might be +12V ignition to the AB14 Lucas amp.
Not sure on the brown bullet connector. Are there more colors on that wire like brown/black? (right location for the oil pressure switch which is BN) Usually "N" or "brown" is battery +12V.
~Paul K.
~Paul K.
LT1 jaguar
10-28-2019 10:58 AM
