Well, there's not much w/ that color combination, and not in that area except if it were a RHD car (or part of an RHD car harness was still in use in 82... which is a possiblity) as those are the right colors and placment for a RHD brake level sensor:
The location is also right for the washer pump connection on an LHD car, but the wrong colors.
Paul K.
Thank you- It has the heavier heat wrap- that wires laid on top of the engine had.... I will see if it reaches to the brake- because its zip-tied up.... I just have a feeling the previous owner tied them up - but no info as to where they may go. Thanks again!!
