Won't stay running for more than 10 minutes
Hello,
Hope someone can help on this. I pulled the rad out had it cleaned. Installed and now the car will only run for about 10 minutes then it shuts down like I turned key off. I thought maybe coolant temp on fuel injection side was bad, replaced it still runs then shuts down. Car ran great until pulled rad. not sure what I should look for. I made sure that I secured all the grounds that I removed by rad. Thanks for any help. The car is 89 XJS v12 with marelli ignition. All the sensor wires were replaced with high heat wire earlier this year.
Grant Francis (11-20-2018)
Oceansidesurf
11-08-2018 10:22 AM
extheaterkid
09-11-2018 12:59 AM
TheOne
06-15-2017 09:09 PM
