X27 and x305 differential compatibility.
Terrific. Although I am unclear, we are talking about the 87+ gkn units right? And what do you mean by entire core units? The whole differential? Probably not what you mean, but what do you mean specifically by that? Thanks a ton!
Yes, basically everything inside the differential case - pinion gear, ring gear, side gears, carrier and limited slip components can be moved into the older case as one lump, but the internals are different enough you can't mix and match old and new gears and carriers for example. The internals need to be all old XJS or all new X300.
The ratio will be different though, an older (pre 1993) XJS will have a 2.88 axle, the later X305 is a 3.58. The late XJS 6.0 V12 with 4 speed transmissions were a 3.54 ratio, with a 3 speed transmission was 2.88.
Ah, I see. Some of the XJ40/X300 did come with limited slip. It was optional in some markets for the 6 cylinder cars, so you may be able to just swap the whole diff assembly. Ratios will vary by market too, for example early USA market XJ40's were 2.88, Canada and nearly the rest of the world was 3.54, soon changing to 3.58. Look at junkyards for the 87 and on 6 cylinder sedans and you might find what you are looking for.
The 6 cylinder XJR (1995-97) were all limited slip, but with a 3.27 ratio. Other optional ratios for various markets were 3.77 and 4.09.
The V8 cars (1998 and on) use a different diff, so those won't be of any use to you.
warrjon
12-22-2011 09:01 PM
