XJ-S 1987 cross-member
cool fuel
My XJS had a fuel line cooler that was connected with the A/C system. Fortunately that bulky old compressor is one of the first items to jettison from the engine compartment. My cooler was on the fuel return line, not the feed. Seemed odd to me. I'm also ordering headers for the exhaust system. I'd like to get rid of some more weight under the hood. I have the 5.3L so every pound helps.
The reason, I believe, for the cooling was to reduce evaporative losses from the tank, nothing to do with fuel temp in the injector rail. The temp of the fuel in the tank could apparently rise to 50°C on a low fuel load! Whether the system had much effect, or was really needed is not clear, as the later models got rid of it.
Greg
That certainly made sense. Thanks for the insight. My XJS is completely stripped, no bumpers or anything I don't need on the track. I replaced both floor-pans with much heavier gauge steel to support the roll-bar and used the same steel to seal off the fuel tank from the driver's compartment. That put another 25 lbs back on the frame but it sure made the body more rigid and stable. I'll try to get some pics up when I get her ready.
Received 1,236 Likes
it'll be interesting to know the final weight after all is done, ready to race!
my XJS rodster, is an actual scaled weight of 3360lbs,1/2 tank fuel, no driver.
drives much more responsive than the 4100lb factory car, like brakes, quick turnin, acceleration, more nimble.
being an open car tho it is somewhat flexible, but it aint no race car, just a fun to drive hi-way cruiser, garage queen,and show car.
That's a great looking XJS! What are you running for brake fluid? Do I have to run Girling fluid in an 87? I'm going to be tearing down the brakes soon after i change my front cross member. Hate to put the wrong fluid in and ruin it. I had heard on a separate forum that the seals were synthetic by then. Is that right?
#28
Still wondering about the EGR system. Does anyone know if it (the EGR system)can be removed from the engine permanently for racing use only? Love to pitch all of that as it's just another potential failure on the race track and really only designed for pollution control from what I know. (I know I left myself open there) Will it cause problems with the computer? The cats have been eliminated and MiG welded to 2 1/4" straight pipes and it doesn't seem to impact the computer at all. Suggestions?
#32
#33
Heating system question..87 XJ-6- my heat comes on normally and then suddenly it seems like the AC comes on without touching any of the controls. It does switch back to heat on occasion too but it is very inconsistent. Anyone have any experience with this Jag Gremlin? I can tear it apart but if someone knows what to specifically look for I would greatly appreciate your input.It has a new divert valve in it. Thanks!
#34
#35
tips
Thanks for the tips on using the forum. I'll check that out. The forum administrator relocated my original thread to this section of the forum. Inadvertently, I started this thread. Please go back to the start and check on my intro post that was moved. I don't think it's possible to hide or hi-jack my own thread. I started it and was involved with several other knowledgeable members when I asked the heating system question about my other 87 Jag.
#38
FS[SouthEast]: Books - Various Jaguar Titles
SCMike
11-25-2015 07:55 AM
