XJ-SC blowing cold :-)
Received 10,979 Likes
On the heater valve itself. It is vacuum operated with an external linkage.
With the engine have a helper turn the temp control from extreme to the other. You actually see the linkage operate.
If it doesn't move it's either broken/stuck, or it isn't being commanded to operate.
Set the control knob to max heat. Remove the vacuum hose at the control valve and feel for vacuum with your thumb over the end of the hose. You should not feel any. Now select max cooling on the controls and check again. You should feel vacuum at the hose.
If the heater valve is operating properly but you're still not getting warm air when you ask for it then there are various possibilities to investigate.
Do you have the Delanair Mark II system, or the Mark III system? The change was made circa 1987. The easiet way to tell is the Mark III system has a 'pull for manual control' capability on the temp selector knob. The Mark II does not.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
