XJ8 engine in a 1994 XJS ?
Has anyone tried putting a XJ8 4.0L engine
into a 1994 XJS 2+2 ?
I was curious once I saw that the 1994 XJS
used the ZF transmission and figured it would be
an interesting match for the XJ8 *(X308) engine.
I know, I know, this is a possible bad idea what with the
XJ8 4.0L having problems with the cylinder sleeves (NikaSil ?).
But, if I were to LUMP a XJS, I'd like to keep it as much Jag as possible.
Eh?
P O R - Press On Regardless
Eh?
Cheers,
ronbros (12-06-2015)
Why not a supercharged AJ16 engine, engine mounts should be the same as the AJ6 and if you get it with the trans 4L80e should fit with minimal fuss.
Or fir AJ6 and turbocharge it even easier
Cheers,
Similar to Forcedair, I have an 02 XJR and a 95 XJS 4.0. I love both cars equally but the difference in performance feels like the cars were made by different manufacturers entirely. The XJR is a rocket and the XJS is nothing special acceleration-wise. But that's the only thing about the XJS that isn't special. Otherwise, it's a fabulous car.
good idea, but i'm more familier with the SDS EFI system, what i have in my XJS V12! been 21yrs , and upgraded 3 times, as knowledge about EFI progresses.
fully adjustable from startup to 9000 rpm.
Even a n/a Jag V8 would make the XJS much quicker with its 290 HP compared to the AJ6 (219HP) or the AJ16 (237HP). I personaly remember my previous '98 XJ8 acceleration being so much quicker than that of my XJS with both cars nearing the 4000lb. No doubt that even the n/a V8 would improve the XJS acceleration by quite a margin, but if one has the choice of using the s/c version instead, well, that would probably make an XJS one of the very best GT cars in history.
Cheers,
Would the XJ8 engine mount up to the 94 - 96 ZF transmission with no
adapter plates? Or would taking the complete engine-trany be the
best way for a swap?
I can't believe someone somewhere hasn't done this yet!
After reading about all of the Chevy Lumps done over the years
I would expect a natural swap of a Jaguar V8 4.xL engine to a XJS had been
attempted. Maybe one of the racing teams had such a project in mind?
And yes there would be some computer to engine wiring harness issues.
No pain - No gain, eh?
ronbros (12-09-2015)
It has been done with the AJ16 6 pot engine and if I had the money I would buy it.
1996 XJS Celebration Coupe SUPERCHARGED., £ 15,000.00 - The site to buy and sell a jaguar car, parts or related services. Brought to you by the Jaguar Enthusiasts Club
warrjon (12-08-2015)
I fear that with the XJS brand on the verge of attaining the same classic status
as the "E" type, there will be a reluctance to change any remaining units.
But, the "E" type has had some interesting mods to it's power plants and transmissions. So, maybe the interest will lead to some nice mods.
This is the way I would head, much easier than engineering a AJV8 swap.
Or you go AJ6 turbo, Arden managed 245kw (333hp) and 580nm from a turbo AJ6 on 0.65bar (9.7psi)
I have many times expressed in this forum my disappointment with Jaguar for not having dropped the s/c AJ16 power plant on the beloved XJS. It would've ended the XJS production with one heck of an exclamation point and probably placed the range's prestige pretty close up there with that of the E-Type once and for all. What a car that would've been, yet, when the opportunity presents itself with a supercharged XJS, the supposed enthusiasts on the subject are nowhere to be found. About a year ago, there were two s/c AJ16 XJS for sale on
eBay, both convertibles, both from the same owner and at a very fair price for what they were, yet they were there forever and they only sold after dropping the price significantly. Are we XJS owners true enthusiasts, or are we just too soft in the performance aggressiveness category? But don't look at me because my kitty does 0 to 60 in 5.2 seconds...
Cheers,
GM produced 91 million small block chevy engines, so cost/prices are super cheap, i have seen junkyards selling them for as little as $50. each, as many as you wanted, piled high as 20 Feet.
that is why a lot ended up in low value vehicles!
now XK8 engines would be much more costly, and need harness and computer, completely different animal.
but my dream is totally over the top, an Audi V12 DIESEL,comes factory twin turbos,twin intercoolers, direct injection, weighs close to same as Jag V12.
factory specs , 500hp ,torque 650lbs ft, , reprogram computor, 650-700hp ,800-850 torque, dont even have to take the engine apart, whats there not to like?
cost WOW, dont ask, a lot.
