XJR-S with 'special' crank and Cosworth pistons?
Hey there,
Has anyone here ever heard of the XJR-S having a different crankshaft than the standard 6.0l V12? I'm not talking about the TWR 6.0l... Just the 5993 ccm V12. According to a user in Germany, his XJR-S from 1992 has a special crankshaft making exactly 5993 ccm and it comes with Cosworth pistons...
All of my litrature says nothing about Cosworth parts nor does it state that the engine is any different than that of the standard 6.0l V12s in facelifts...
I know the TWR 6.0l engines are more powerful, have a different crank, different conrods and have a different overall displacement due to these differencss and I would understand, that the TWR engine could have some totally different pistons due to it being a 'tamed' race car engine, but I find it hard to believe the standard XJR-S has something like that...!?
Anyone heard of this?
Damien
Damien
Daim,
Remember that there are 3 different types of 6 litre engines (+ the Lister 6.0 engine!)
The first one was the TWR 6 litre engine. I'm not sure of its exact displacement. I have read that it used a longer throw 80mm crank, but I've also read that it had a bigger bore and specially forged pistons. I have also read publications where it was stated that it had Cosworth pistons.
Then there was the 6 litre engine that was developed by JaguarSport for the pre-facelift XJR-S. This used a long-throw 78.5 crank to give a displacement of 5993 and a compression ratio of 11.2:1. This engine continued into the facelift XJR-S. It used Zytek engine management and I've also read that it had Cosworth pistons.
Then Jaguar developed the "standard" 6 litre engine and the XJR-S ceased production. The new "standard" 6 litre engine also used a long-throw 78.5 crank, displaced 5993 but had a compression ratio of 11:1
As JaguarSport was partially derived from the original TWR team, I think it's quite possible that the XJR-S 6 litre had Cosworth pistons.
Not sure if that helps or confuses!
Paul
Paul
Daim (09-27-2016)
That may be a typo but no cars had welded cranks. The vast majority of V12's ran forged cranks although some later on had a chilled cast crank.
Probably just splitting hairs but l would have said the "standard" crank in a Jag V12 is the forged steel crank. Relatively few were the cast variety and as best l remember they were restricted to some of the production 6 litre models.
ronbros (10-05-2016)
I read somewhere that later 6l used chilled cast iron crankshaft, but don't know when this happened.
ptjs1 (09-30-2016)
I have a 1994 6.0L engine out of a US XJ12 (soon to be 6.7L) to go in my XJS and it has a forged crank.
If your motor is running lucas or marelli ignition it will have a forged steel crank.
Warren / Paul_59,
Thank you both for your replies. I've been doing a bit of digging around and it seems the crank changed at the intro of the x300 and at engine number 12471. That means that early standard 6.0 XJS had forged cranks (as per XJ40) and late 6.0 XJS (from about VIN 199400) have cast cranks (as per x300).
Paul
Paul
Damien
Damien
Warren,
As I mentioned, remember that there is a difference between the TWR 6.0 engine built up until 1988, and the XJR-S 6.0 engine. The XJR-S was assembled by JaguarSport, not by TWR, although it was built in the ex-TWR building. The TWR 6.0 uses an 80.0 crank, the JaguarSport 6.0 uses a 78.5 crank.
Paul
Paul
AJ6 list the XJR-s crank as 78.5mm, doesn't really say if this is the TWR or JaguarSport????
