XJS 4.0 1991 Braking problems
Whilst driving the car the other, I heard a pop. The brakes then failed. There has been no loss of brake fulid. When I started it this morning, the ABS warnnig light was on. I checked all the a relays, replaced a blown fuse (not sure which one as I have no diagram for the internal fuses box) and sprayed a bit of WD40. There now seems to pressure in the pedal and stop the car. I have been unale to conduct a proper road test as I couldnt get it out the drive way. Has anyody else had this sort of problem? If this hasnt fixed it, my money is on the ABS acculminator.
ANy help or advice would welcomed. Dan
