XJS 4.0 gearbox fault light
I'll look at voltage next with a independent voltmeter. I'll put results on this post soon hopefully.
All the best.
I've owned the same car for 20+ yrs. and have had identical issue with trans light off and on. There is no code that appears on the window where the clock is. The warning light on the dash at start-up is the only source. It is annoying, yes. If your trans oil is serviced per owners manual, I would ignore it. My car is @ 220K miles and I haven't had any debilitating impact. I would suggest you spray some cleaner under the MAS on the RED part attached and wiring going to it. It's a maintenance item rarely mentioned but I've found it helps. The light comes on as a signal failure to that RED part indicating the trans will loose its shift signal and you may notice a "hard" shift until the light is off as it should be.
Dave
Dave
Dave
Dave
My car has only done 65k miles. When you say MAS, do you mean mass airflow sensor?
My car does go into limp mode and resets once i turn off and on.
All the best,
Zarathustra.
Dave
Dave
All the best,
Zarathustra.
[QUOTE=Zarathushtra;2734878]Thanks Dave,
All the best,
Zarathustra.[/QUOTE
I finally got round to working on xjs today.
Left battery disconnected for a mknth. Started and still same issue.
Cleaned all relay connections, MAS connection, checked all fused and now she seems fine. Only done approximately 5 miles but gearbox light off and gearbox works normally.
Hope it stays so.
Thanks everyone.
All the best,
Zarathustra.[/QUOTE
Hope it stays so.
Thanks everyone.
The following 2 users liked this post by Zarathushtra:
Greg in France (05-11-2024),
ptjs1 (05-10-2024)
#28
Hello, I have a '93 built in 1992. Right at about 65k miles, the gearbox began acting up. Turns out the rubber parts to the rear transmission mount were worn out. There was way to much play when pusing up on the gearbox from below. Bought a new kit for $200, had it installed and no more problems. Jag does issue a word of warning for the person doing the install. Support the gearbox while the mount is disassembled or the drop in weight could possibly break a switch mounted on the firewall. Anyway, best of luck.
#30
#31
#32
yes it did Paul. The rubber gaskets on the rear gearbox mount were so worn out, the gearbox was literally flopping around. The mount should give the gearbox just some slight upward movement but with the rubbers worn out, their was a great deal of movement.
#33
Finally got round to check voltages
before start approx 12.5 v
After starting approx 13.5v, idling at 1200rpm 13.5v.
Do you know if my car would have a gearbox ecu and if so where it is located?
Thanks.
