XJS 5.3 To 6.0L
#41
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1632x918/wp_20150626_13_44_44_pro_ee388c2390e2a3f87d8926239a6d6d032aa0b4d5.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1632x918/wp_20150626_13_45_23_pro_e62d04187789af4db46111765ad1bc18b48d8bf8.jpg)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1632x918/wp_20150626_13_47_41_pro_84580996642b211eaa329371c96d842aafba3403.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1632x918/wp_20150626_13_47_46_pro_ccce6f086f236702f0c25cb716a030b1b810f15a.jpg)
well time to finish the Rad and fans Just need to replace the Flaps and wiring
New Bush's and Rad rubbers
Fuel pipes looking at the ones that run from the Tank Under the car there a bit tatty so was wondering if any body had replaced them and if so what with
also was thinking of running them in the car ?
as for the flaps when you pop revit them back in if you do it from the u channel side I had to drill a hole in a hobby stick and press the revit into it and press it into the channel so it would bottom out and be tight when done could use a small washer, or pop then from the other side which I did not like the way it looked
looks great !
What fan is that in the big fan shroud?
#43
FWIW, If you have twin electric fans with the circular guard round the edge of the blades, you do not need the flaps at all as they will not be doing anything. The guards prevent the fan short-circuiting the airflow. The fans need to be as close to the rad fins as possible, with a couple of bits of dense foam here and there to prevent the guards chafing the fins.
Greg
Greg
